Back when I was a teenager, I worked for a garage that you all by now should know! This same garage at that time, was trying to help me get a "first" car or even truck and I worked for it, the owner found me a '78 Dodge Power Wagon, W-100. I was all for it, and he simply wanted me to work for the cost of the truck for 2 weeks and the truck was mine to work on after hours, and so, I took his offer as it was thee only way I was gonna have a 16th birthday vehicle.
The truck was 4x4, it had a Mopar 360 in it. and was pretty solid body and frame! BUT upon checking the engine, it turns out that 360 was seriously "pounded" a lot of little things point that it was ran and used, with little to NO oil in the engine! ;-|
So, the owner, Don told me, we'll yank it, and see what I can find. I was agreeing to this as that 360 was never gonna last long knowing it had been used with little to no oil in it. The engine itself, needed both heads replaced, and had a soft wrist pin in the rotating kit, and I simply wasn't going to do all I wanted to do to it, and then risk the engine blowing for sure. So, about 2 more weeks AFTER this, the owner, Don, found a '69 Plymouth 440 "Super Commando" engine. Basically a 440, with a 4 barrel carburetor. Told me he can get it for me, if I agee'd to work yet another week, for the cost of the engine. SO, I got it. I at this point already owned the truck my 2 weeks of working for free were up! SO, it was in to this that far and Don, always treated me good kid or not.....
Was a bit of work to get that engine into the truck, but we did it, I only ever got to "test" drive it, as I could run 2 miles up the road, and back from meing an employee to the garage on the very out skirts of my home town, 4 houses away from where I grew up in Pennsylvania.
So, this model, is going to be built, as my truck would have been when it was done, and I had my drivers license!!!!! Not a lot of "building" just Mopar stuff Don had given to me over the time this truck was being built, road worthy, however you want to look at it. SADLY, I never did get it road worthy, as one day were were working on a '68 or '69 Chevy Camaro, the truck was outside parked along the road, in front of the garage in the late winter and a 4 door Chevy Celebrity came down the road flyin hit Anti-skid on the road and T-boned my truck! Sadly totaling the truck, BUT never hurt the 440 in it. SO Don & I both tried to buy the truck back from the insurance and they (hers) would NOT sell it to me or him.......Why? Well thats where Don & I both got a good lesson, that engine we had in the truck the 440 4 barrel out of a Plymouth wasn't what we thought! The block number indicated this motor was a 440 Plymouth Interceptor! AND WAS FULLY in tact from the '68 or '69 Plymouth Fury it came out of with all the "Interceptor" parts in the block, Cam, all that, it was all there...... With it coupled to a 4 speed Mopar transmission! So were S.O.L. on getting it back due to this fact! With that all said, now off to the model..... More explaining to be done with the pictures of this whole story as the kit unfolds!
Now as you all know, I'm a big "stock" builder no less. BUT this truck model will be built as I had it started.....
The engine before it went into the truck, was repainted the same color it originally was.....Mopar Engine Turquoise. BUT upon getting this engine in the truck Don himself came to me one day with a box, while I was sanding on the roof of a car in the shop to be painted, poked me in the arm pit with this box that had valve covers in it, pretty much NEW ones, I was like Don, those on the 440 are OK, I don't need new ones. Hes like take them, I have had these things and since you got an engine for them, there yours......
Pretty much NEW stock 440 valve covers, BUT, they were chromed OEM parts! 8D I got to say, I was a happy camper!
The belts are only "posed" on the front, I got a little ways to go on the engine yet!
I got to replace the oil filter and mount, on my trip down south, and got home, I somehow managed to knock it off and lost it, but I can say here I am not hurt on it, as I wasn't feeling it all that much so, bad things sometimes happen for a reason, I'll replace it with a bit better done detail (was a gluebomb part!)
Then Don suggested, I remove the stock Carter AFB or AFC carburetor off the engine due to its age and replace it, which I did, got the transferring plate to mount a Carter Thermoquad in its place (better winter starting), which with the stock carb it did start hard, the Thermoquad once jetted right started the ole 440 with not even a grind start over the winter I worked on it like the Carter AFB or AFC carb did.....I was glad I did it! The last picture, shows the Thermoquad in place and fuel supply line going to it with filter!
More to follow right after these short messages! ENJOY!
