You could be working on a freakin Turbo Pitiful Thing.....
Good here hear it is up and going without wondering when it will strand you next.
I think you said that too loud, as I got stranded again this late morning. The truck was running perfect until today when I was way to work, and luckily it died about 2 miles from my house. I was driving and it was running perfect, then I caught up with a slow driver and it slowed down like normal but then it just starts slowing down on its own and not like normal, I go to put my foot in it a little and nothing. Then the "check engine" light comes in and it is flashing, so immediately I pulled over and I know the flashing light is not a good sign. Good thing is I called my stepfather and he rescued me, so we then go home and get the code reader then go back and plug it in to see what it says. We plugged it in and it said multiple misfires, I had to get it towed back to my house and it could not be driven. At first I had my doubts that the engine was toast, BUT I dont know as it starts but does not want to at all idle. We put our foot to the floor and it just coughs and does not do anything, just stays at 1,000-1,500 rpm. Any thoughts on what might be wrong? Idler pulley or maybe a sensor of some type?......
What were the code numbers?
Hi All,
IT FINALLY HAPPENED! I took the big green beast out today, and I was going to a friends house 2 towns over from where I live. I was in his town and I decided to stop at Dunkin Donuts, and boy was that a mistake. It was running great until I got in his town. I pull into Dunkin Donuts, I am waiting in line with the car in drive NOT neutal and all of a sudden it stalls. Here's the kicker, normally it starts right back up after it stalls and continues running. THIS TIME it does not want to restart......perfect. So what I did was pushed it out of the way and let it sit for a half hour with the hood open. I start it up and it was fine after that. THAT said I had to tell my friend sorry I am not coming with the car acting up, and I did indeed make it home and luckily did not have to have it towed. So that prompted and motivated me to order a crank sensor. Here is what I ordered.....
1998 DODGE DURANGO 5.2L V8 Crankshaft Position Sensor | RockAuto
More Information for NTK EH0178
I also got this from Walmart as well to put in the gas tank when it runs low on gas and I need to fill the car up again, just in case View attachment 17443
But how much fuel are you squeezing in?
Some gauges are just slow.
I think that is more a function of the rate at which the bowser is pumping, and the rate at which the air is escaping from the tank. Our pumps up here, Manitoba Canada, often trip the shut-off with those crummy small filler holes. Every car I have had, since they went to those, has done that.the gas pump goes then stops goes then stops
