. Let's see if this works.
I thought I heard a rumble coming from your area ? I thought it was a storm coming . lol Seriously , Thanks for posting that , It sounds good and I needed something to cheer me up today .
Not sure about the carb issue without seeing it , But as far as the valve covers leaking . How are you ventilating the crank case ? It's a shot in the dark , but could you be building up pressure causing the valve covers to leak ?I have some issues to work out. I have a small fuel leak in a brand new CSU carb and an oil leak from the valve covers. These are magnum heads with a rubber gasket with metal insert. Not sure why they are not sealing but have to figure that out before I start it again.
It's always the little stuff that shouldn't happen but does that drive you nut's on a fresh build . Two of the things that come to mind with mine was carb and distributor . Both new but both had issues and of course it was right when I was trying to bring it out .I have -10 lines in the valve covers going to catch cans so no pressure. I found the problem tonight when I took it apart. The gaskets are designed for stock head bolts. I am using ARP studs so the stud nuts are slightly taller and larger in diameter. So what happened is the gasket was sitting on top of the nut instead of being completely flat and it cracked the metal liner and tore the gasket. I will have to trim the new set to fit around the stud. And the carb leak was a bad diaphragm on the fron accelerator pump.
I think it just might be a lil chilly around here for that just yet Mob . But I bet he's looking forward to spring even more now .Now that those are fixed, go out and get on that thing! Have fun breaking it in and causing mischief in MA!
Aren't the low beams on top, or am I wrong? Been a while since I've seen one at night.View attachment 9067 View attachment 9068 View attachment 9069 View attachment 9070 Cockpit is almost finished all lights now working.
