K-Note72
Yeah a toggle switch is easy, that's basically all there is to the O/D button (no ECU dependency). I just rather have the lockup controlled by some kinda circuit that energized either when the trans is higher than 2nd gear or is going high enough speed that it'd easily be in 3rd or 4th gear. That way if I'm cruising down the highway it'd engage and save some gas, or if I'm going down the hill and the engine is near idle it'll also be engaged and make the engine control my speed. Sure the stock ECU would control all that, and according to that one post all the wiring is there to just hookup the lockup to the ECU (if not already equipped), but if I hop up the engine when I drop it in a power wagon then I may as well just go ECU-delete.i am nearly in the same boat planning to install a 91 42 h in my D200 the main modification wil be to have 2 separate toggle switch for the lockup and overdrive. which is easily doable. check this PATC Dodge Performance Transmissions, 46RE, 47RE, 48RE, 68RFE
ALTHOUGH, after going back to read the Hemmings article they also shared a fix for this in the last paragraph:
"Install a vacuum switch and two oil pressure switches, which allows the overdrive to engage before releasing torque-converter lockup. PATC's design calls for installing a 7-pound normally open vacuum switch, similar to those used to drive an hour meter, to a direct hot wire (with an inline fuse) off of the ignition switch. The hot wire out of this vacuum switch will run to the center pin of the three-pin connector. The vacuum switch will allow you to engage the torque converter lockup and the overdrive solenoid, if engine vacuum has reached seven pounds. It will also disengage both when you kick the throttle up and engine vacuum drops below 3 pounds. This allows you to revert back to third gear to pass a car or help the vehicle negotiate a hill. If you install two oil pressure switches, this will fine-tune the speeds at which the torque converter lockup engages (this keeps the transmission running cooler) and when the overdrive solenoid engages. These are installed in a pipe tee in the governor pressure tap, which has a pipe plug in this hole from the factory. This is on the passenger side of the transmission case, on a thick mounting rib, just below the upper tail shaft mounting bolt."
