Basketcase
I'd say that with almost 7000 miles, you did a good job on the engine.
That's how they're made, melting plastic as it rotates. I used to make Hummer fuel tanks and we would fix them the same way when they had pinholes, just melt some into the hole until it's good.Only why I have gotten polypropylene to weld and hold was adding more of the same material. Simply melt it in.
Don’t use a torch, be fixing a bigger holeThat's how they're made, melting plastic as it rotates. I used to make Hummer fuel tanks and we would fix them the same way when they had pinholes, just melt some into the hole until it's good.
Bigger hole would be the least of worries.Don’t use a torch, be fixing a bigger hole
