Transmission issues
Shorty Thompson
Taylorville , Illinois
Hello all! I have a 2000 Chevy Silvarado HD 2500 4x4 base model. Has the 6.0L in it with the 4L80E ( I think ) I know it's the 80's series. First off I bought it from a Farm auction knowing it had a knock in the engine. In reality it had a broken rod. Got an '02 6.0 and had it put in before I drove it 1 foot. I always thought the transmission didn't shift right. Then 1 day, it quit shifting out of 2nd gear. took a to a tranny shop where they found oil in the plug that plugs into the transmission. At that point it was decided that a $600.00 repair was better than a $2500.00 rebuild. Fixed it and the truck shifted again. Until. Until now. As previously mentioned it won't shift out of 2nd gear as a general rule. Once in a great while it'll shift from 1st to 2nd then that's it. Truck & transmission has about 227 plus on it and the drivetrain. Warned against flushing it. Has anyone else had any issues like this?
I had something similar with the 46re in my Durango before with the oil in the electric plug. The 2nd gear only thing is limp mode
Dreading this but for the first time in my 59 years in actually shopping GM instead of Dodge because we have outgrown our 2 durangos. I need something bigger. And no way to Ford (an expedition with a v6 won't work) is this what I'm in for? Looking at tahoes yukons Escalade and suburban. Would prefer the 6.0 or early 6.2 before about 2017
Don, my truck was used as a farm truck. Keep that in mind, okay. My truck also has 227 thousand miles on it before i got it. Keep that in mind. Also keep in mind that I did not know how the truck was driven before I got it. Just know that I do like my truck. Before this last episode I drove that truck flawlessly 129.0 miles, used 6.36 gallons of gas @ 19miles to the gallon. I was shocked. Now then! If I do a flush they tell me that I do not want to do that. Why? because it'll plug up air vents and puke tranny fluid everywhere. Done that been there already. Also they tell me when whoever does transmission flushes doesn't normally do them correctly anyway. See I'm told that when you do a trans flushing your suppose to pull the torque converter away from the engine and flush it seperately. Most shops don't.
Now then! 7/1/2026! I got in my truck and drove it today. As was,,,, trans was in Limp mode and didn't shift till I got to the lumber store. Then went straight to the local Walmarts. Was in Walmarts for about 30 minutes. Came out. Got in the truck. Started for home and the trans shifted beautifully for about 1 1/2 miles, then went back into limp mode again.
Check the trans connector again for fluid, I have seen fluid cause strange issues. If there is fluid in the connector again, they sell a replacement seal.
https://www.ebay.com/itm/256334211102?msockid=211fc5438eea685e02c6d2538f4d690c
It definitely sounds like a electronic issue which fluid in the connector can cause. Do you have access to a scan tool? It would be very helpful to see what the comptuer is commanding verse what it is actually doing
Yeah go figure. I did a hard reboot/reset by disconnecting the battery for an over night reboot. The Check Engine stayed off for 2-3 days then came back on and now the truck shift again. Scan tool? Best I can do is run it up to Auto Zone and have them Scan it. I am seriously starting to thinking it's a wiring issue. I told another guy that contacted me that when I had the replacement engine put in the guy didn't put anything under the transmission and it pulled and laid on the wiring under it for about 2 weeks. I also had a friend also tell me a couple things, # 1, my transfer case is manual shift, however has an electronic plug on it, Check it and see if that plug also has oil on the connector. # 2, Apparrently somehow, someway that genre can rub a hole in the top of the transfer case near the red dot as well. If it's lost transfer case oil it can make up false readings that can make it shift funny as well.
Yup
Had problems with my 01 Durango 46RE with an oily connector. I replaced the park neutral switch (it's different from the 3 pin neutral safety switch starting that year) and the solenoids while I had the trans apart, and sprayed the hell out of the wiring harness ends of the connector, and so far no more problems with mine... I remember something about the durangos with the 4.7 had some kind of pressure switch in the PS line that would leak thru the switch and it would wick up the wire harness and cause all kinds of weird crap to go on, the fix for it was a new harness. If you caught it early enough possibly whatever solenoids or connection that is oily you might be able to blow it out with electric terminal cleaner (similar to brake clean but different) and be good. Or cut the pigtail off and solder another one in if the fluid hasn't migrated very far into the harness
I decided to have mine scanned to find out what codes were set and I have thess;# 1, Knock sensor vibration sesor " A " Circuit low- Says the electric circuit is low, # 2, O2 Sensor low voltage bank 2, # 3; O2 sensor Bank 1 sensor 1, and O2 sensor bank 2 sensor bank 2 Vibration sensor
None of those codes are going to cause trans issues. Knock sensors and the harness for them are common issues, they are under the intake manifold. O2 sensors are also common. Have you checked the trans connector again for fluid?
I had a similar experience with my 2001 V-10 Dodge 2500. Changed the fluid & filter 3-4 times, after I cleaned up the shift solenoids & it was much better. It was not shifting right & slipping so bad, that I thought the trans was SHOT & it's still going strong. That oil (Transmission oil?) is probably just an "O" ring seal gone bad on the connector & that could be the main problem. Shift solenoids also seem to be a common problem according to a mechanic I know who's done quite a few of them over the years.
All the shift solenoids have been replaced with new, so has the harness. Now I am leaning towards clean trans fluid. Honestly I paid attention this time and it does look dark.
Yup, your filter could be gummed up. I know ATF isn't cheap but changing it & the filter 3-4 times in a year saved me over $3500, & that was installing the trans & T/C myself.
Well right now I can tell you this. When I had the solenoids & wire harness replced he also changed the filter. However. I have recently looked at the trans fluid again and I can tell you that it's black/dark. I've ordered a new trans pan gasket and will pick it up tomorrow. However ,,,,! SWEET JESUS!!!!!!!! When did tranny fluid jump so high in pricings?
How about the wiring in the truck outside the trans?;
That's a good question. Don,,,,, I can honestly tell you that when I had this motor put in the idiot did not prop the transmission up on anything and left the bell housing push on the wire harness for over a week. We used the truck to grab another car and come to find out the 4x4 didn't work , so I had to get that fixed and come to find out the idiot left the harness loose and the drag length kept pulling on it and pulled a couple wires in two. With that knowledge. Yes the harness could be damaged in that area as well.
Didn't you have an old square body Dodge with a/6 in it? I still remember when you came up my way and picked up those f body parts...
I have 2 80s ones. An 85 with a/6 and an 83 3/4 ton that I have blown apart all the way to the bare frame. I'm building a 360 mag for it that will have a thermoquad on top ..
I had one hell of a time finding an actual automotive machine shop.
I ended up going all the way to rantoul to find one
No. I had a 2nd Gen Dodge, before that I had a '91 F-350 crew cab and before that I had a '79 F-100 standard cab. Whished I had that ol' '79 back again. Had that thing for 15 years.
Yes, tranny fluid was pretty high last time I bought it, a little over a year ago. It was $36 for a 5qt container for the ATF+4 that is used in my truck. A friend just GAVE me about 10qts of genuine Mopar ATF+4 (He works at a dealer near me) & I have 1 or 2 spare filters left I got from Rock Auto pretty cheap. I have the pan gaskets also. Probably change the fluid in it again soon. When I dropped the pan the first time, I installed a drain plug to make it easier on me.
P.S. Adding an external trans oil cooler is an excellent idea. Mine has the one in the radiator & an external one from the factory. I'm pretty sure the Cummins diesel engines come with them too. You may be able to get one from a salvage yard near you pretty cheap, from a Duramax or H.D gas engine equipped truck.
fixin on changing the tranny fluid this weekend, then running it. I'll be checking the electrical plugs too. But to be honest! I am looking at another truck and selling this headache.
