Transmission issues
Shorty Thompson
Taylorville , Illinois
Hello all! I have a 2000 Chevy Silvarado HD 2500 4x4 base model. Has the 6.0L in it with the 4L80E ( I think ) I know it's the 80's series. First off I bought it from a Farm auction knowing it had a knock in the engine. In reality it had a broken rod. Got an '02 6.0 and had it put in before I drove it 1 foot. I always thought the transmission didn't shift right. Then 1 day, it quit shifting out of 2nd gear. took a to a tranny shop where they found oil in the plug that plugs into the transmission. At that point it was decided that a $600.00 repair was better than a $2500.00 rebuild. Fixed it and the truck shifted again. Until. Until now. As previously mentioned it won't shift out of 2nd gear as a general rule. Once in a great while it'll shift from 1st to 2nd then that's it. Truck & transmission has about 227 plus on it and the drivetrain. Warned against flushing it. Has anyone else had any issues like this?
I had something similar with the 46re in my Durango before with the oil in the electric plug. The 2nd gear only thing is limp mode
Dreading this but for the first time in my 59 years in actually shopping GM instead of Dodge because we have outgrown our 2 durangos. I need something bigger. And no way to Ford (an expedition with a v6 won't work) is this what I'm in for? Looking at tahoes yukons Escalade and suburban. Would prefer the 6.0 or early 6.2 before about 2017
Don, my truck was used as a farm truck. Keep that in mind, okay. My truck also has 227 thousand miles on it before i got it. Keep that in mind. Also keep in mind that I did not know how the truck was driven before I got it. Just know that I do like my truck. Before this last episode I drove that truck flawlessly 129.0 miles, used 6.36 gallons of gas @ 19miles to the gallon. I was shocked. Now then! If I do a flush they tell me that I do not want to do that. Why? because it'll plug up air vents and puke tranny fluid everywhere. Done that been there already. Also they tell me when whoever does transmission flushes doesn't normally do them correctly anyway. See I'm told that when you do a trans flushing your suppose to pull the torque converter away from the engine and flush it seperately. Most shops don't.
Now then! 7/1/2026! I got in my truck and drove it today. As was,,,, trans was in Limp mode and didn't shift till I got to the lumber store. Then went straight to the local Walmarts. Was in Walmarts for about 30 minutes. Came out. Got in the truck. Started for home and the trans shifted beautifully for about 1 1/2 miles, then went back into limp mode again.
Check the trans connector again for fluid, I have seen fluid cause strange issues. If there is fluid in the connector again, they sell a replacement seal.
https://www.ebay.com/itm/256334211102?msockid=211fc5438eea685e02c6d2538f4d690c
It definitely sounds like a electronic issue which fluid in the connector can cause. Do you have access to a scan tool? It would be very helpful to see what the comptuer is commanding verse what it is actually doing
Yeah go figure. I did a hard reboot/reset by disconnecting the battery for an over night reboot. The Check Engine stayed off for 2-3 days then came back on and now the truck shift again. Scan tool? Best I can do is run it up to Auto Zone and have them Scan it. I am seriously starting to thinking it's a wiring issue. I told another guy that contacted me that when I had the replacement engine put in the guy didn't put anything under the transmission and it pulled and laid on the wiring under it for about 2 weeks. I also had a friend also tell me a couple things, # 1, my transfer case is manual shift, however has an electronic plug on it, Check it and see if that plug also has oil on the connector. # 2, Apparrently somehow, someway that genre can rub a hole in the top of the transfer case near the red dot as well. If it's lost transfer case oil it can make up false readings that can make it shift funny as well.
Yup
Had problems with my 01 Durango 46RE with an oily connector. I replaced the park neutral switch (it's different from the 3 pin neutral safety switch starting that year) and the solenoids while I had the trans apart, and sprayed the hell out of the wiring harness ends of the connector, and so far no more problems with mine... I remember something about the durangos with the 4.7 had some kind of pressure switch in the PS line that would leak thru the switch and it would wick up the wire harness and cause all kinds of weird crap to go on, the fix for it was a new harness. If you caught it early enough possibly whatever solenoids or connection that is oily you might be able to blow it out with electric terminal cleaner (similar to brake clean but different) and be good. Or cut the pigtail off and solder another one in if the fluid hasn't migrated very far into the harness
I decided to have mine scanned to find out what codes were set and I have thess;# 1, Knock sensor vibration sesor " A " Circuit low- Says the electric circuit is low, # 2, O2 Sensor low voltage bank 2, # 3; O2 sensor Bank 1 sensor 1, and O2 sensor bank 2 sensor bank 2 Vibration sensor
None of those codes are going to cause trans issues. Knock sensors and the harness for them are common issues, they are under the intake manifold. O2 sensors are also common. Have you checked the trans connector again for fluid?
