67 Power Wagon
Well its been a bit, a bit of trial & error (I have to admit to it, I had some issues with getting this right!) BUT thats why I keep "trying"..... WELL, to give everyone a heads up, keep in-mind, I want this thing to be the BIGGEST, BADDEST, engine ANY of you can EVER imagine! To the point of, when you see it, it jumps out and bites you............. Thats the goal here (I mean, really its name after all is "Doomz Day", right!?) -NOT because of the meaning of the term "Dooms Day" but after the name of the engine that powers it.. the "Dooms Day Machine" Chrysler called it! BUT I'm playing off that, with the name and a little twist with the spelling, but you all get it by now. And, those who know me knows how I roll that way!
So anyway, to start, I originally wanted to use the 14-71 Superchargers that I molded and have made already.... Sadly, I wasn't pleased with their looks. They'd be OK on other builds, but not this one..... I just wasn't "feeling" them in the sense they'd be used here.....
SO, with that, I sat out to build something...................different? Yeah, they sure are "different". Kit-bashed, yes, from existing parts, made to be bigger then originally made by the factory. Started with parts from the S'Cool Bus kit, that I saved....
Those Superchargers are monster-ous, BUT they are after-all 1/24th scale, NOT 1/25th so I made them fit the suit, and slightly under-sized them, BUT still kept them "BIG" for looks.... IF that makes any sense!
Now as you see here, I have the newest parts set out, with the first BIGGER idea I had, with the 14-71 resin part setting with whats to come! To start, I took the factory S'Cool Bus blower "body" and split it down the center.... This was going to slightly "shrink" it. Narrowing it, makes it fit the Plenum a bit better, and gave it a slightly longer looks thats not so wide. I re-built it adding in 1/8th inch thick rod, to the center, so I didn't make it too narrow but took out about 1/16th of an inch in width by doing this! SOLID bar too, makes it easy to "shape" it to the form, of the blower body itself! And giving a good base to glue too!
Then, you see the front and rear blower body plates, those have things done to them as well! Between the yellow blower body, and the rein 14071 I molded you see a clear piece, that I machined! This is a body extension that a larger then 10-71 would have! This will be added to the back of the blower body!
That clear part, mounted to the back of the blower body..... This clear part? BOY, I tell you, that thing was difficult to make and get it right! See, there is no "true way of knowing what looks right, what is too big, or too small! Because its "looks" NOT dimensions! Plus, in making that part, you first have to turn the part down to be round rod..... THEN when you think you have it, right, you then have to put it into the milling machine, to mill to flat spots on it, top and bottom! BUT, if the round turning isn't right, when you mill either of the flat spots, you can't go back and turn the round part down any further as the lathe won't grab the part right to make the turnings true! SO, one small mistake? You get to start all over again! Thank God, these parts are just little, It took 2 tries before I got the 3rd one (seen here) right!
This shows the front of the blower body!
Now sadly, I didn't get pictures of the work done to the front and rear plates for the blower, BUT as your about to see, I did some work to both those parts as well!
The front plate that has the blower drive pulley extrusion, got a thicker plate as the real 16-71 would have.... As well the rear plate, also got a thicker plate base too, these "extensions would be for bolting reasons, and flanges for such as well as size all in one!
Now to take the resin 1`4-71 that I mold, and sit it right beside the NEWEST creation my 16-71 Supercharger....
A tad difference in size, yes? I LIKE it! The new one looks GREAT! After a couple of tries, I find, one day, to let it sit and think about it, makes all the difference!
Now so that all are aware of it, I had to make these TWICE! As I'm using Double inverted-"V" Superchargers on this build!
Stay tuned, more to follow! Comments are always welcome, ENJOY!
