56hemitruck
I picked up a 56 dodge pick up a couple of years ago. Took me a while to figure out my build. Decided to use a Dakota frame and a 341 Desoto Hemi with a A-518. My dad had a hot rod 56 with a 330 Desoto when I was a kid. I wanted to create a tribute to my dad's old truck.
I've got the motor in the frame and the cab set on. I had to set the motor back 7" or so for steering and exhaust clearance. The rear trans mount I reused but I had to add tubing to the inside of the frame for the crossmember to slide back on. Front motor mount brackets came from Hot Heads. But the frame to insulator portion is going to be a fab job to clear the rack on the drivers side. passenger side be a little easier.
I'm a little concerned about how much work will go into making a trans tunnel and firewall.
