I can think of a few things to do with it but what you going to do with it?
I love it and your idea's sound good to me also Bruce! Get some nice Alcoa's on it will make that truck look good right now!
Sounds great Bruce. Have you checked the engine tunnel height yet the 24 valve Cummins is a tall critter?
They apparently built these with inline 6 truck engines also.
At 89" and the Cummins up front you going to have to add weight to keep to rear safely on the the ground with the trailer disconnected? I have a friend down here with an early 90's D250 Cummins 2:wheel drive and his biggest complaint is not enough weight on the back without a load to get the heavy noise around and that is with the front wheels under the engine. Yours should end up about 3/4ths in front of the axle to get the trans and drive shaft in at 89". Just a thought!
The engine must be set back like in the vans of that era. Could you post some interior pictures so any one under 50 will know what is being discussed here about engine placement? The engine sitting that far back will make a world of difference on the balance of things. Does the cab tilt or does it just have a compartment cover? Would be neat to put a tilt cab on if it doesn't already have one and would make working on the Cummins so much easier.
You need to let us in on how you found this and what it was used for originally some day. I have seen Dodge stub noses but nothing but pictures of anything similar to your Fargo.
You are correct on the Dodge build in the US, is it as strange to you as the Fargo name in Canada is to us southerners? Are they Rams there now as they are here or has the Fargo name be retained?
