Crack in Frame at Steering Sector
General Dodge Truck Discussions
  1. bigds65
    bigds65Member
    15
    10
    Dec 14, 2019
    Burlison TN
    Anyone out there ever have a Dodge pickup frame crack where the steering sector bolts to the frame? I have, three in a row a 79 frame then an 80 frame and a 77 all cracked at the steering sector. "Dang"
  2. 99Ram
    99RamWell-Known Member
    664
    355
    Apr 17, 2017
    Virginia
    3 Wow. I never have. Had a 79 that had some frame rot behind gas tank it was a 2wd and 30yrs old at the time. My dad's old 80 model was 4wd frame was thicker on it. It was in great shape when my nephew totaled it around 2008-09.
  3. badvert65
    badvert65Member
    13
    21
    Nov 2, 2019
    Brightwood VA
    I believe that there is a reinforcing plate on the later 80's trucks. I don't know when that started. I had a 72 with frame cracks there. My two 89 4x4's have a plate that sandwiches to the frame where the steering box mounts. I have a stripped Ramcharger that I might be able to get a picture from.
    • Like Like x 1
    • bigds65
      bigds65Member
      15
      10
      Dec 14, 2019
      Burlison TN
      That would be awesome. My lil red express frame has two small hairline cracks next to two of bolt holes for the steering sector. I wont to repair and reinforce the area.
    • badvert65
      badvert65Member
      13
      21
      Nov 2, 2019
      Brightwood VA
      On my 72 pickup, when you turned the steering wheel, you could watch the frame flex by the steering box. There was a broken rivet on the front frame cross brace. I welded that back up but it still kept cracking. I will try to post a pic of the reinforcing plate.
    • bigds65
      bigds65Member
      15
      10
      Dec 14, 2019
      Burlison TN
      Thanks a lot. I'll be watching for them.
    • Polara_500
      Polara_500Well-Known Member
      681
      454
      Aug 9, 2015
      NW Minnesota
      It's a fairly common problem, there is a plate and a brace available somewhere - or at least was. I've never had the issue so never chased it down.
      • Agree Agree x 1
      • bigds65
        bigds65Member
        15
        10
        Dec 14, 2019
        Burlison TN
        I'll do a search. thanks man.
      • badvert65
        badvert65Member
        13
        21
        Nov 2, 2019
        Brightwood VA
        • Like Like x 1
        • bigds65
          bigds65Member
          15
          10
          Dec 14, 2019
          Burlison TN
          Thanks man I had no idea they were available. And happy new year. Don Taylor.
          • Like Like x 1
          • bigds65
            bigds65Member
            15
            10
            Dec 14, 2019
            Burlison TN
            Thanks to all for the help.
          • LocuMob
            LocuMobFluid Technician
            3,566
            2208
            Mar 20, 2015
            Blue Earth, Mn
            Thanks for bringing it up, I need to make a list to get my truck on the road, and this was one of the things I need to look at.
            • Like Like x 1
            • MoparsOnly
              MoparsOnlyThe snozberries taste like snozberries.
              217
              53
              Sep 24, 2015
              South Carolina
              I think I saw something about this sometime ago on trucks when stacey david from gearz was the host. I think he ended up welding a plate in or boxing in the frame I can't remember.
            • 65 sporty
              65 sportyWell-Known Member
              1,808
              1057
              Aug 8, 2015
              Marlette, Mi
              Stacey is still the host
              • Agree Agree x 1
              • MoparsOnly
                217
                53
                Sep 24, 2015
                South Carolina
                Yes he Is. I'm thinking It was early on when he did Sgt.Rock.
                • Like Like x 1
                • LocuMob
                  3,566
                  2208
                  Mar 20, 2015
                  Blue Earth, Mn
                  That was a cool show, can't remember the name. I wanted one of those Power Wagons, found one for cheap, passed, then realized what an idiot I was. But it needed a lot of money thrown at it, but man, it would have been sweet. It would have gotten a newer drivetrain while keeping the original appearance, for the most part.
                  • Like Like x 1
                  • 85crewcabbie
                    85crewcabbieActive Member
                    63
                    9
                    Oct 21, 2011
                    Tucson, AZ
                    I bought a used '88 150 2WD recently and was surprised to find the frame cracked around the steering box mounting holes. One of the cracks extended into the frame rail a couple inches. Folks say it's common but in the last 20 years and a dozen or more of these '81-'93 trucks I'd never come across it before. I took it to a heavy truck repair shop and they welded it up for $150. After a year and half and approx 50K miles still fine for what it's worth.
                    • Like Like x 1
                    • 7mopar
                      7moparWell-Known Member
                      1,963
                      1081
                      Dec 21, 2013
                      Hitting curbs, potholes and beating on things sideways with the front bumper are probably there worst things on the Dodge frame at the steering box.
                    • badvert65
                      badvert65Member
                      13
                      21
                      Nov 2, 2019
                      Brightwood VA
                      Well what's the point of having a truck, then?
                      • Like Like x 1
                      • 85crewcabbie
                        63
                        9
                        Oct 21, 2011
                        Tucson, AZ
                        @badvert65 - I think 7mopar was trying to distinguish between use and abuse. With no history on my '88 referenced above I wondered what it took to break the steering box loose. With no history, who can say. In getting the truck road worthy it became clear that it had gone off-road in a very unfriendly manner at some point in it's life. The oil pan was bent and torn as well as the driveshaft being bent. But even if it had one accident event it's hard to imagine that alone being the cause of the cracking around the steering box mount. I've often wondered if bouncing the left front wheel off of parking lot stops, over and over might also contribute. As a precaution I try to stop short of them instead of stopping/parking by "feel".
