Converter & gear ratio
Casca2525
Ontario Canada
I have a 79 sportsman van, 318 standard, 440 optional, it's a mini motorhome, currently just screaming it will do 55, I want to put a cube van body on it and tow a 32 foot house trailer, I have a 75 new yorker with the 440 to drop in, gears are std mini motorhome dana 70's and the convertor is std 75 new Yorker, I currently want to avoid tearing in to the 440, the new Yorker runs and drives great, , need suggestions on whether the gearing and or convertor should be changed
Ok, thanks, you think the stall, diameter etc on the 440 converter should be good?
Looking forward to spring so I can try to make some headway on this, every time I drive it now I expect it to punch out a rod it's reving so high
