42RH into my 87
mopar_nocar
TEXAS
Dug a 42RH out of a 92 Dakota today. Gonna put a 5.2 Magnum and this thing in my 87 D150. Currently running 3.55s in an 8 1/4 for rear end with 30" tires. Thinking about throwing more gear in it, but will decide after I get this thing running and see how I like it.
PLAN is to get this going and then rebuild the front end in a few months. THEN get someone to body work it an paint it up.
As it sits right now...well actually I threw the 42RH in the bed after these pics.
Little set-back today...JY Magnum motor has no compression on cylinder #4...blows out the exhaust port during the test. I am assuming bad exhaust valve at this point. More digging tomorrow, but I don't see how this motor isn't going back to the JY.
sb
Pretty clean D. Sorry to hear that about the engine, hope you get it straight soon. Remember the 42 has a lower first gear so that will act a lower gears to a certain extent. You going to run carb or EFI. If EFI stock Mag or aftermarket? Been thinking about the same combo in my Challenger.
Plan to run a Chinese Air Gap intake manifold with a Carter 600 cfm carb I took off my long gone 74 4x4. The 42RH (at least initially) will be controlled by manual switches in the cab for 4th gear/lock up. The serpentine brackets and FI manifold & TB are up for sale over on FABO.
The truck is already running the GM HEI conversion and I will dial in the distributor to the new motor...if I ever get it built.
ATM I am letting all the cylinders soak in ATF, I pulled the rocker arms off the number four cylinder oiled up the stems and re-installed. Valves are moving, but obviously the exhaust valve was in the open position for a long time in the JY and either the seat is messed up, has something blocking it or the stem has a rusty spot on it.
The whole point of picking this motor at the JY was for the warranty. We will see Monday if that works out. Very worst case scenario I am building the 5.2L because the JY welched on my warranty.
sb
Well after everything soaking in ATF over night, I spun the motor for about 20 seconds with no holes plugged...Re-ran the compression test:
Cyl 1 = 185, Cyl 3 = 185, Cyl 5 = 180, Cyl 7= 175
Cyl 2 = 150, Cyl 4 = 170 (!), cyl 6 = 175, cyl 8 = 165 (I oiled #2 in came up to 170)
Cyl 4 had 20 psi the first time I tested the motor. ATF is magic in a bottle, apparently.
SO, now I am going to rotate the crank a few times by hand and let it sit a few hours and re-test it...that'll be the proof in the pudding and determine my next move -- incidentally oil pressure is good, had to plug the sensor hole and getting oil thru he oil filter.
sb
Please share what you do for trans kickdown. I have not had luck with Lokar running a carb and RH trans.
I assumed from looking at the lever and linkage compared to my 87 with a 999 the kickdown would transfer over. Is this not the case in your experience?
sb
Glad the ATF trick worked out, that stuff saves more engines than people give it credit for!
Biggest thing it did (i think) was dissolve combustion and/or oil varnish that was holding the #4 exhaust open. Probably did not hurt the rings either. My dad and uncle claimed to know folks who ran their engine (!) on nothing but Type F...not sure of the veracity, but they said the inside of the motor was CLEAN.
sb
sb
Not in my experience. 1, holley carbs have a different amount of travel than AVS based carbs and I always run holley double pumpers. 2, I personally have 4 different length, mopar trans kick down levers, the ones that go on the trans but the equalizer has always been that sliding rod up at the carb for adjustment. 3, the factory linkage takes up so much room, hinders exhaust manifold/header options. Not as big s deal with a D but major with an E body.
Well crap. Big assumption on my part was that the kickdown was not an obstacle. May need to re-examine the switch over...I really don't want to mess around with Lokar type cables -- not my favorite 'cuz they never seem to stay fixed. Could just be me.
Linkage for the kick down should only be different on the top side. I have modified brackets in the past and have had good luck.
I to don't see the attraction to Lokar. Might be the fancy cable look, but I just don't get it.
It's different at the input shaft also because the RH is controlled by a cable, not hard linkage. That's where I always had trouble because the ratio for a RH vs 904 or 727 is quite different. *And the cable actually pulls instead of pushing like the linkage.
I was also wanting feedback because I want to run early mag exhaust manifolds and am pretty sure the linkage interferes with the mani exit.
Guess the linkage thing is something that will have to be dealt with. I haven't gotten that far yet.
The 92 Dakota I pulled the transmission out of was all solid linkage. Visually, while first lying under the truck then trudging over to look at the RH in the garage, the >LOOK< the same...but nothing is set up yet. I am gonna finish up the Magnum then start working on that next problem.
sb
