Kern Dog
I took a bit of break from the progress. I had other stuff to do and now I had the time to resume this project.
I often jump into projects with no clear plan on how to get to the end but I do know what I want it to look like when it is done.
This is no different. I figure that these panels will need 3 or 4 coats of paint to cover.
I've thought of installing the cladding then spraying the paint and clear in place. That still may happen but I might switch it up a little.
I actually could spray 2 coats of paint on everything...install the cladding....then spray 2 more coats and the clear.
Why do it this way?
I have to paint some of the stuff off of the truck. The grilles, the tailgate, hood scoop and rear bumper all will turn out better if painted off the truck.
3-4 coats, whatever it takes.
If I am mixing paint, why not go ahead and spray what I can?
Prior to primer, I did a mock up on the right side:
The trick will be to hang the cladding so that the top edges all line up evenly.
The cladding is held on in a couple of ways. There are screws in the flange in the wheel openings, two sided tape at the edges and plastic pegs.
The rear corners have additional hangers that I don't have. If the dealer cannot get them, I'll have to make something.
There is one that sits below the taillights. The picture below is of a truck bed at a wrecking yard. the picture is flipped upside down because the bed was stored upside down.
The white circles show the bracket at the rear and 3 clips at the side that I need to mount the rear corner cladding pieces.
Why do it this way?
