Kern Dog
I've been the original owner of this truck since just before Thanksgiving 2007:
It is an SLT model in the short bed, regular cab configuration. It has the 5.7, the 545 trans and 3.92 gears in the original 9 1/4" axle.
It has been a great truck and I intend to keep it.
For a few months, I've been dealing with the MIL coming on and staying on.
In Mopar terms, the MIL stands for Malfunction Indicator Light/Lamp. This is the same as what is often called the "Check Engine" light but the CE started with Chevrolet and GM.
I don't own any GM products so I'll refer to the proper terms that Ma Mopar used for their cars and trucks.
Anyway.... I have a parts store code reader that can read and clear codes. What I've been getting is cylinder 6 misfire, random misfire, bank running too rich, bank running too lean. Each condition had a different code number.
In short, the engine has at least one head gasket leaking small amounts of coolant into the cylinders upon shutdown. At a cold start, it will blow a little steam, run slightly rough but clear up in less than a minute and idle like new.
Up until a little while ago, the MIL could be cleared and stay off until another cold start. Lately, I clear the code and it pops back on in a few minutes.
Last week I pulled the # 6 coil pack, then the # 6 spark plugs. The plugs looked fine, the coil pack did too.
I put in a different coil pack from my spare 5.7 I have in the shop out back. It started fine, idled fine, no MIL either. A restart a few minutes later gave the same results.
I did not do anything except replace the coil pack. The old one was original. Can you believe it was going bad after only 397,000 miles ???
Yesterday, the rough idle cam back. It smooths out over 1000 rpm but the 600 rpm idle in gear is no longer smooth.
I'm going to try changing the injectors. I have a spare set from the replacement 5.7 I bought a few months back. I had those injectors serviced by a friend in Rancho Cordova that cleans and repairs fuel injectors. His name? Doctor Injector.
I know that this engine is on borrowed time but it still runs great. Power seems decent, oil pressure is good, fuel economy isn't much different from when it was new.
Hopefully the cleaner injectors will get it running smooth again and allow that MIL to go out.
