    Dismiss Notice
1967 Dodge D200 need help!!!
Discussion in 'Classic Dodge Trucks - Pre 1981' started by Kcmysunshine09, Aug 14, 2019.
  1. Kcmysunshine09
    Kcmysunshine09Member
    6
    8
    Aug 14, 2019
    Los Angeles
    Help with my son’s truck! We’ve recently replaced the coil and fuel pump as it would crank but not turn over. After finally getting the correct order of the distributor wires, it fired up and ran for a day. The following day it fired up but stalled after five minutes in the drive way. Won’t turnover since. Anyone have advice? Spark plugs are all new and show spark when tested. So frustrated.
  2. kiwigtx
    578
    486
    Jun 16, 2011
    Auckland
    Has the truck been sitting idle for a long time? It may have bad fuel or clogged fuel lines.
    Do you have access to a multimeter - volts and ohms specifically. Testing voltage and continuity of cable/wiring can be helpful if we provide some advice.
    Hopefully you have a replaceable fuel filter near the pump...it might pay to check the condition if it is old --- or check what is inside it. You can buy cheaper transparent filters - good for looking at the fuel flow and cleanliness, and seeing air bubbles etc.
    Condition of the spark plugs might be something else you could check....they may be quite old and already sooted/carbonned up.
    Lots to look at , so hopefully you can rule things out one by one by checking things for us. :)
  3. kiwigtx
    578
    486
    Jun 16, 2011
    Auckland
    Anything to report?
  4. Rusty Junk
    Rusty JunkActive Member
    68
    60
    Jul 28, 2019
    North central Iowa
    The possibilities are rusty tank plugging filters and carb, float sunk, stuck needle and seat, fuel lines with leaks sucking air, bad gas and bad fuel pump or any combination of the above. Make sure you have fuel at the carb and work from there. I'd also look for rust in the fuel, a common problem in a 50 year old vehicle.
    • Like Like x 1
    • Polara_500
      Polara_500Well-Known Member
      646
      399
      Aug 9, 2015
      NW Minnesota
      Your definition of "won't turn over"? Do you mean that it turns over while cranking but won't fire and turn without the key to "start"? Need to make sure we're on the same page.
      • Agree Agree x 4
      • Kcmysunshine09
        6
        8
        Aug 14, 2019
        Los Angeles
        Thank you! You were right it cranks but doesn’t start. Last night we finally got it to start. I checked the choke, it wasn’t flooded, the fuel pump, distributor and spark plugs are all new. It fired up this morning and 20 miles down the road at a stop light it just died and would fire back up. We pushed it to a side street and now have to have it towed. I don’t see a choke knob in the cab so other than viewing it from above it appears to be working. I don’t know what to check next but will get a multimeter tonight.
      • kiwigtx
        578
        486
        Jun 16, 2011
        Auckland
        Driving 20 miles then stops....sounds like a broken wire to me...probably near the ballast resistor.
      • Kcmysunshine09
        6
        8
        Aug 14, 2019
        Los Angeles
        Thank you I’m on my way to buy a multimeter. It was also suggested we look at the ignition switch.
        • Like Like x 1
        • 7mopar
          7moparWell-Known Member
          1,748
          812
          Dec 21, 2013
          Jumper wire from positive side of battery to the ballast input and see if it starts. It may not be ideal to drive that way but will give you an idea were to start on the electrical. Just remember to disconnect it to shut the truck off.
          • Like Like x 1
          • Kcmysunshine09
            6
            8
            Aug 14, 2019
            Los Angeles
            I’m on my way to meet him and the tow truck so we will try this first.
          • SCOTT M LITTON
            SCOTT M LITTONNew Member
            Aug 20, 2019
            manassas va 20155
            Drives for awhile and then stops? Make sure that the exhaust is flowing free. If the truck has sat for some time make sure nothing built a mouse nest in the tail pipe. Once the exhause builds up in the cyclinders it leaves no room for fresh gas to enter the chambers.
          • 7mopar
            1,748
            812
            Dec 21, 2013
            Built up gasses in the exhaust will usually contribute to a huge explosion, blowing the exhaust apart instead of killing the engine. Not implying it could never happen. Just highly unlikely.
          • Kcmysunshine09
            6
            8
            Aug 14, 2019
            Los Angeles
            I wanted to thank all of you, you have been just amazing helping make suggestions. I’ll just say it again as a single mom who only knows what she learned from her dad growing up, you guys made all the difference in the world. When he replaced the coil, fuel pump, other items that have been suggested he disconnected the battery. That metal Part (not sure of the name) that is on the battery terminal was cracked so he replaced it. When everybody suggested electrical we looked at the wires that were fed into it and it was loose. So all of you were correct that it would make contact and then it would pull off causing everything to not fire correctly. We were able to fix that last night and it is running like it has never ran before. Again I just can’t thank you enough for being so helpful, knowledgeable and in my book just amazing. Thank you again
            • Like Like x 4
            • 7mopar
              1,748
              812
              Dec 21, 2013
              Glad to hear you got it going and that we were of some help. This was one of those times it was simple. We often look at the difficult first and we all seen to make that mistake.
              • Like Like x 1
              • Agree Agree x 1
              • Rusty Junk
                68
                60
                Jul 28, 2019
                North central Iowa
                We are just grooming a woman to be a car guy.....:)
                • Like Like x 4
                • Polara_500
                  646
                  399
                  Aug 9, 2015
                  NW Minnesota
                  Sounds like she's already most of the way there. :smuggrin:
                  • Agree Agree x 3
                  • Like Like x 1
                  • kiwigtx
                    578
                    486
                    Jun 16, 2011
                    Auckland
                    I am pleased we were able to offer some good advice. :)
                    • Like Like x 1
                    • Agree Agree x 1
                    • LocuMob
                      LocuMobFluid Technician
                      3,376
                      1,952
                      Mar 20, 2015
                      Blue Earth, Mn
                      I'm glad you got the truck running well. Now go take some pictures so we can check out this ride!
                      • Like Like x 1
                      • Agree Agree x 1
                        Dismiss Notice
