2nd gen ram mileage/mpg improvements
Hey everyone, its been a few weeks. I have some updates
1st, the fuel pump took a crap on me so it's got a new one now, doubt that'll do anything for mileage but we shall see. on my last tank, I averaged 12 mpg, which is better, but still not where i want to be. on this current tank, it's at 10 mpg (just ball-parking with the fuel gauge and the trip odometer, so not entirely accurate) which is partially due to hell once again freezing over again in Iowa, and also due to the header bolts backing out again (I swear, these damn things are going to be the bane of my existence.
2nd, I got some crap done to the truck to help with some fuel economy. the rear is now lowered 4 inches (the front was already dropped 2 inches, just hadn't gotten around to pulling the bed off to do the rear) and the spare tire has also been removed, but has been replaced with a couple of sandbags and my brother's wheels in the bed. it's supposed to warm up again next week and stay warm, so hopefully the sandbags will come out and then i can replace my bed liner with a bed mat.
now, time for everyone's favorite part of the gameshow. the questions
1st (this one is mainly for AJ, but anyone is welcome to chime in), is there a formula or something to calculate mpg improvement from reducing weight? it seems like something like that could be helpful.
2nd, does anyone know how I can get these damn headers to stop leaking? currently, I have grade 8 bolts with the spring style lock washers and tightened the piss out of all of them
thanks,
Yeah, the secret is in the gaskets, and having thick flanges.
The hot/cold cycles just do that.
My TTI headers have about the thickest flanges I've ever seen, and the last set of gaskets that I bought, are the the thickest I've ever run. Together they are the best sealing chit that I've ever run. They have been on there since 2004 with no leaks, no loosening, no tightening required; and no, I do not recall the brand of the gasket, sorry; but I do remember that they were not cheap.
Oh, and I did NOT tighten the piss out of them, lol. But, worse, I think, is that my 367 has Edelbrock heads....IDK, maybe that's the secret, lol.
IDK if there is or not, I kindof doubt it.
I don't think there can be.
But there is a formula for computing fuel consumption to Power. As in, if your particular chassis requires "X" amount of power to go, "Y" mph, then the amount of fuel for that situation, can be calculated.
Somewhere I once read, that it takes 1/2 pound of fuel per horsepower, per hour.
So then,
If your chassis requires 60 hp to go 60 mph, that would be;
(60 x .5) 6pounds per gallon(ppg) = 5 gallons, and
5 gallons for 60 miles =12 miles per gallon.
If you then shave a bunch of weight off, and your chassis then requires only 55hp to go 60 mph, then;
(55 x .5)/6ppg =4.58 gallons, and that would be 13mpg.
But I do not know of any formula, that can directly predict mpg improvement from changes in weight. There may be one, I just don't know of it.
Some modern EFI computers can compute mpg from rate of fuel injected over distance traveled, but there is gonna be some tricky math involved.
Finally, Fuel consumption is rarely measured in steady-state. When you go by "the fuel used per trip", the trip usually includes periods when the vehicle is not moving, or is accelerating up to speed, and so on. Thus on short trips, those activities, plus warm-ups, can easily cut your economy in half.
For example, my 4-banger DD, in summer on long hauls, can hit in the range of 32mpg/US. But in winter, running back and forth to town, is lucky to get 60% of that, and with warm-ups, even less. But, I imagine, that you would know that.
Plus, trucks are usually calibrated rich in "open Loop" until the O2s kick in;
and, the O2s are kicked off under load sooner than in cars, which may have wide-band sensors..
and, any time the CEL is on, the ECU is/or may be, in "open loop" .
So then, in every case, it's very important that the CEL is NOT on, and that it's function has not been compromised..... like with an aftermarket programmer.
How thick were the flanges on your TTI's? My headers had some damn thick flanges, but they're made from chineseium (they were all of 165 bucks new if that tells you anything). I think I'm going to wait on buying gaskets as I have a 360 that's going in and I'm going to get a set of pacesetter long tubes to replace the china headers.
I'm guessing, at least 3/8ths inch.
IIRC, I paid $495 for them, in 1999, plus shipping into Canada; and the dual 3" exhaust was about the same. This system is still on the car with only some minor rust-thru in the valleys of the merges.
Car was a DD until 2005/6. Every fall I would swap a 318 in, and every spring the 367 would go back in. and every year a different trans for at least one of them, and the 318 always got winter gears. Only the 318 ever got an automatic..... but not every winter, lol.
Another week, another update.
The good news, I averaged 12.4 mpg on my last tank (trip to Iowa City helped with that. Running 80 mph with 35-40 mph winds, however, did not.) we are moving in the right direction.
Now to the bad news, the exhaust leak is back and is worse than before. I'm totally not pulling my hair out from it (suggestions for gaskets would be appreciated). This turd of a 318 is also huffing oil like it's auditioning for a lead role in Cheech and Chong, so that's great. Over the 2800 miles between oil changes, it burnt/leaked out 3.5 quarts of oil. Part of that is from the oil pan gasket (of course, the one gasket I didn't replace before putting the motor in) but most of it is coming out of the breathers. I got rid of the factory PCV stuff and replaced it with the standard filters that you'd see on an old school motor, so now my bitchin custom painted valve covers are coated in an oil film. Not as much is coming from the exhaust as I'd thought. When I start it, a nice blue cloud comes out of the tip, and it hazes a bit when I get on it, but it's not that bad.
I also checked the plugs and they had some soot on them, but not nearly as bad as I thought they'd be. They did smell a lot like oil though, so I'm sure that's totally fine.
To the questions. Is there a way to help the blow by on my precious gem of a 318? I'm running 10w30 full synthetic high mileage blend oil with a wix filter, along with a bottle of Lucas full synthetic oil treatment (I thought this would help with the ring sealing) does anyone have any mystery sauces or piston rings in a bottle that actually work?
Thanks,
You have to use a pcv valve on a 318 and make sure its working/breathing properly I bought a car one time on the cheap because of oil use and leakage I changed the breather on the valve cover opposite the pcv valve side that was plugged and no more oil use it really ran nice for many miles, also if it smokes on start up your valve seals are bad and with the right tools you dont have to pull the heads to change them. Eventually oil use will plug your cat converter and will start dropping your vacuum
By your description of blow-by. my guess is
If the fueling is half-decent accurate, which the fuel mileage is pointing to, then
either.
1) the plate on the bottom of the "keg" is sucking crankcase fumes, or
2) the oil rings are, wore out or stuck, or
3) the compression rings are, wore out or stuck.
For diagnoses, I would;
1) start with a crankcase vacuum test,
2) returning the PCV to proper operating status,
3) and do a compression test.
4) and because I have a blow-by tester, I would test that.
Then;
If the keg is NOT sucking air from the valley,
I would steam-clean the chambers and down into the rings, By spritzing water thru the throttle body, while she's on fast-idle, then take her for a spin to expel the water.
Hey everyone,
Ok, it's been a hot minute since I've posted. the truck was out of commission for about a month getting painted because that's obviously important for fuel economy. Now, I did fix the header leak while it was all apart and, aside the fact that the tick was driving me bonkers, the mileage has been getting better. I've gotten about 13 mpg on my last 2 fill ups while driving like a complete moron, so we're going in the right direction.
I do have some more plans coming up before I hopefully leave for basic training (waiting on waivers). First, I need to spray some water into it to do a steam clean. Now, I should be able to hold it at about 2000 ish rpm and mist some water down the throttle body with a normal spray bottle, right? Second, I need to find all the parts to put the PCV system back on at some point. Am I going to notice any power increase or the truck not gassing out an entire parking lot when I start it?
Anyways, that's my little update for everyone. Thanks.
Hey everyone, I'm looking to improve my mileage I'm my 01 ram. It's a rcsb 2wd with a 318, 3.55 gears, and a 2/4 drop kit (the front at least, it's been too damn cold to do the rear). Currently, the truck has a 3x14 air cleaner, a set of shorty headers, stock y-pipe to a 2.5 in/3 out flowmaster with a 3 inch side dump. Anyways, the truck has been getting 11 mpg with mainly highway driving. I've been chalking this up to mainly letting the truck warm up for so long (hell has frozen over in Iowa recently). If anyone has some ideas, I'd greatly appreciate it
Thanks
Hey Mopar_Fanatic,
I have pretty much the same truck.
Could you let me know what drop kit you used and where you got it?
I see kits for up to 1999 but thats it.
No Listing for 2001 that I could find.
Thanks.
BTW... My Truck. 2001 RCSB 2WD, Sport w/SLT 5.2L
