Wiper bushings....
Paserdener TX
My 95 Dakota seems to eat these up every couple of years but since I don't drive it all that much in the rain, well, they don't seem to last long. I figured since they are nylon/plastic or whatever, they don't need to be lubed but they do go on easier with the use of WD-40. Am I doing something wrong here? The pins they fit over look ok to me....
I would suspect the WD-40 is to blame. Could be causing a number of issues. Could be breaking down the nylon bushing or any coatings on it. Also if there ever was any grease on there the WD-40 for sure cleaned it all out and once the WD-40 is dry you have nothing lubing the bushings. Even though it says its can be used to lube things WD-40 is not really good for that.
Yah use some sort of grease . WD 40 is a penatrateing oil not a lubracant and wount last . This may sound crazy and I know I'm opening up myself to a bunch of joke's but I've had the best luck with vasaline . After going thew three set's of bushing's in my Ramcharger in two winters I tried it just because I did'nt have any fresh grease on hand when I installed the last set about three years ago . So far so good .
Well, last summer we had a drought here but not this year. So far so good on the bushings....and I didn't use any WD-40 but I'll be danged if I remember what was used lol. Think it was the WLG....
I just replaced my original wiper bushings on my 79 lil red exp. ( I'm the original owner) because it fell apart...LOL......hows that for an original part? The best part is, I walked into the dodge dealer, and they had a bag with 6 in it, still on the shelf....so I bought them all. I was completely shocked they had them! ,after all this truck is 33 years old.
Yeah I got them for my 72 D100 I use to have. Now I can get them in the help isle at the box parts store.
Remember that Mopar ran the same bushing for at least 30 years. I have a 68 Dart with them and a 1989 Dakota with the same bushings.
My local dealer didn't have them but quoted me a price.....way high.
Made in China?
Yup...had to replace them on my 74 Pickup once and my 95 Dakota a couple of times.
Technically not supposed to put any lubricant thats petroleum based on any plastic or rubber. It breaks the substance down. Thats what lithium and silicone base lubricants were designed for.
Well, my 95 Dakota needs them again....and so does my 96 Dakota. I wonder what's in my 97 2500? Never had to fix the wipers on that one. Watch it creator now lol. The 95's been broken for a while now but since I don't drive it in the rain much at all, I've been putting it off. Hate doing them!
Take my advice. Use the genuine Mopar bushings. The aftermarket bushing suck. The will not last long. The Mopar bushings come with lube in them.
I wrote the following for a post on For A-Bodies Only (FABO): Putting it here as FYI for those who have not worked with them...
The polyurethane bushings, or retainers, appeared on the 1973 A-body and B-body models, then spread throughout most product lines in subsequent years, continuing through the 1990s on some models, including trucks.
The bushings were not initially serviced separately, but were later released as Chrysler number 3799089, or 03799089. They are still available through Chrysler. The bushings can be difficult to change if attempting it with the linkage still in the vehicle. Those cars with linkage under the dash such as A-bodies and 66-70 B-bodies are not as difficult as those with linkage in cowl, such as 71 and later B bodies and E-bodies. 72-93 D/W trucks are in the middle of difficulty/ease with the removable cowl sheet metal. I have done it in all these cars and trucks, but I prefer removing the linkage and working on the bench, plus I can attend to other things that may need attention while the linkage is out. If one bushing has failed due to age, the others may soon follow suit anyway. Following is how I install them with the linkage out of the vehicle, and it takes longer to clean up the parts and gather tools than to install the actual bushings.
1.) Assemble a fixture tool to install the bushings such as the following that I made:
- 5/16" bolt, about 1"-1/5" long, with the threads on the end ground down and deburred enough to insert without touching the bushing edges, (adjust the bolt exposed end beyond the nut to fit a bushing without pressing on the "back" face),
- 5/16" nut for the bolt, installed before grinding the threads,
- a ~1970 sway bar link washer or similar ~1" large radius curved washer, (the curve roughly matches the profile of the bushing, and the edge contacts the linkage before pressing too far),
- a sleeve that fits around the "back" side of the bushing, or 11/16" 12-point washer, (the sleeve I have is tapered in the opening which helps alignment and preventing damage to the bushing)
- a 3/8" Belleville washer if needed.
2.) Note the direction of the old bushing installed. Remove the old bushing remains and clean the link where the bushing mounts.
3.) Support the back side of the linkage on the sleeve or socket. If the bushing does not contain grease inside the opening, add white lithium grease, to about halfway fill the pocket. Place the bushing on the opening and ensure it clears the sleeve or socket. Place the washer over the bushing and insert the bolt/nut into the washer and bushing.
4.) While holding the linkage/bushing/tool, and using a small hammer, sharply, but moderately, rap the bolt head which should seat the bushing in the link. NOTE: If the washer contacts the link first allowing the bushing to spring back, place the Belleville washer under the larger washer to allow edge clearance of the larger washer.
NOTE: Lubricant for the outside of the bushing should not be required to install it. If desired, add a small amount of lithium grease or silicone grease/spray to the outside.
4a.) Alternatively to using the hammer, place the linkage/bushing/tool setup in the jaws of large rib joint pliers and squeeze to install the bushing.
5.) Install the bushing on the pivot post by placing the socket or sleeve on the back side over the bushing. Place bushing opening over the post. Using the large rib joint pliers, the squeeze the socket and post pilot together to install and seat the bushing. NOTE: Do not push on the bushing itself, use the socket or sleeve to push on the metal linkage. If the bushing pushes through the linkage hole, push carefully on the back of the bushing taking care to not mar or distort the bushing itself.
The Chrysler 3799089 bushings I have used are superior to aftermarket bushings that I tried. I've seen about a 15-25 year service life from the Chrysler original and replacement bushings. Much less life for aftermarket, plus the install fit did not seem as clean. I had a bag of unknown brand aftermarket bushings turn brown and fall apart in the bag after several years. I last stocked up on Chrysler bushings in 2002:
Note that the Chrysler bushings contain white lithium grease. The aftermarket may not. The Chrysler bushings are polyurethane, and specify/use lithium grease. Add grease to aftermarket bushings that may not have grease. Lithium grease is as original, but silicone grease could be an alternative if the the bushing material is unknown.
I just did this on my 1979 Newport. R-bodies, such as my Newport, have hidden wipers with the linkage in the cowl like E-bodies, 1971-later B-bodies, etc. One bushing had broken, but the others were not far behind. All were replaced with Chrysler 3799089 bushings. I replaced the original bushings in the 90s, and the Chrysler 3799089 I used back then were just now replaced. So, on this car, I'm getting about 22 years and 150000 miles per set.
Linkage with new bushings ready to install:
I appreciate all of the info and pics! Can you tell me the differences of the two part numbers? Also, do you know which one would work the best with the 1st gen Dakotas?
If you mean the difference between 3799089 and 03799089, they are the same part. Different sources may list one or the other, but most should recognize either format.
Requesting either number at a dealer should get the same thing.
Just drove by the closest Dodge dealer on Friday....think I'll call them first. They're 10 miles away. Thanks!
I didn't look at the whole number once I saw a '0' starting digit lol
