Anyone know the spline on the 2500 full floating axles? Also, do any of the shims from a Dana 60 work in the 70?
Wow, was surprised to see this thread brought back to life! Anyways, I replaced my gears and installed a Trac-loc diff but don't remember too much about the shims.....and don't even remember what the spline count was lol. Have a pretty decent stash of shims since I built lots of rears over the years but this was my first 70. Did another 60 shortly after and then an 8 3/4 with a spool and now that I'm heading for 74, I'm not wanting to do anymore for others.The 2500 full-floating axles usually have 30 splines, but it’s best to confirm by checking the specific year and model. For the shims, some from a Dana 60 can work in a Dana 70, but not all. It depends on the part of the axle you’re working on, like the carrier or pinion. Double-check the sizes to make sure they match before using them.
Ring gear size of the 70 is 10.5 but it uses the same size diff guts as the 60. Don't remember if the bearings are larger or not. I think they are. The housing uses the same size diff cover but the overall size of the housing is larger. If you really want to increase the strength of the rear, go with the Dana 80 as the 70 isn't much more durable than the 60....imo.How much difference between a 60 and a 70?
I found a Trac Lok for my 70 on Ebay.I've redone a couple of Dana 60 before, just re bearing jobs. Got a couple places I can borrow that case stretcher tool to be able to sneak the carrier back in....
Will probably do the one In my current project, no problem but never been into in over 200k... I'd like to add a track lok to it if I do.
