charm
I'm a bit confused by what I'm seeing. When I look up balancers for my truck, they don't look anything like this. The rubber is broken, coming out, and I'm certain it's slipped so it needs to be replaced. I just want to make sure I get something correct.
The block is stamped as a 1975, so likely original to my 75 d300. The heads are NOT magnum heads so I don't think that's been swapped out. I'm worried that this is for an externally balanced crank. I'd prefer to not pull the engine, although if I must then I must.
Thoughts on this balancer?
