K-Note72
So I have this pet project in mind that I'm entertaining for later on down the road. It's inspired by a late 70s D100 my Gramps had back in the day, that I had some nostalgic memories of (namely remember the grill). This is more of a passion project that I'd imagine goes against "what everybody else does", so here's what I got in mind:
-Mid-to-late 70s D100, either stepside or shortbed panel w/ small lift (they both look good so it's hard to pick)
-225 Slant 6
-Aftermarket EFI
-Turbo setup with mild boost (mild enough to keep stock engine internals)
-Either 518/46RH or a500 trans (see below)
-833 geared somewhere between 3.55 or 4.10
Since I have a half hour commute going anywhere, a small engine and a decent cruising trans are vital to making it cost-effective in the long run (the turbo makes it peppy and worthwhile). I'd like the capability to tow a car on occasion, so that's where I figure on beefier springs, bigger (power) brakes and a trans oil cooler. The turbo adds to fuel economy when I'm cruising (excess of teens mpg would be nice), and beef up power when I'm towing or just laying on the gas. I know that the "bigger engine" crowd will chime in at some point, but tbh if a naturally aspirated slant came stock in a D100 then a slant with a turbo and overdrive trans will do just fine (Ford's doing the same thing with the ecoboost in their F150). Sure I could probably save on the work and just get a newer pickup that could do all these things, but the passion just wouldn't be there (plus I'm seeing long-term reliability with cars and trucks go down as they become more and more reliant on electronics, the basic EFI is the most I feel comfortable relying on them).
There are PLENTY of turbo slant projects out there, so I have options to pick from as far as turbo setups go. I just have a few questions I was wondering if anybody could answer:
-225 Slant 6
-Aftermarket EFI
- 518 vs 46RH, which trans is which? I have a 91 Dakota with the V8 4x4 and auto trans w/ selectable OD, marketed as the tow haul pkg so I figured that was a good starting point. However, I just can't find out which one that trans is, and I've gotten conflicting claims as to which is which. UPDATE: I think in fact my Dakota actually has the A500 unit, the 518 seems to be for the Ram and the 500 fits my Dakota model year. Remember, my trans has the pushbotton selectable under/overdrive
- Anyone who has dealt with a boost setup, any idea what's a good mild boost pressure? Again, just want a turbo setup I can run with EFI and electric fuel delivery and can run without having to upgrade engine internals. If needed, I could consider an oil cooler
- What is the usual idle rpm for the slant? Not a major question upfront, just curious what stall the torque converter will need to be.
