7mopar
They move the engine forward or back?
How much taller can the MoPo valve covers be over the Micky T's I run ? I think with the headers , It come's down to quality control . I bet , If he got another set of the same brand , He'd have different issues .The valve cover issue is those MP covers, stock covers fit better but don't look as good as those you have, they are nice! Ah, headers. I hope mine fit better by TV I won't know for years. Maybe someone will come out with a real truck header, that works! That should be a real rocket of a truck once you get all the issues worked out.
I'll go.out to the garage and see if I can get to them. If I can I'll take a pic or two.How much taller can the MoPo valve covers be over the Micky T's I run ? I think with the headers , It come's down to quality control . I bet , If he got another set of the same brand , He'd have different issues .
Roughly 3/4"How much taller can the MoPo valve covers be over the Micky T's I run ? I think with the headers , It come's down to quality control . I bet , If he got another set of the same brand , He'd have different issues .
That's good to know Mob . I was thinking of getting a polished set for the Warlock and after seeing 68GTX's engine , I'm liking the look !Roughly 3/4"
Sorry the pictures suck, but you get the idea.
Like thisIt's sounding like to me either the engine is sitting to high or to far back . Or maybe both . You did put the motor mount bracket's on the back of the ears on the engine , correct ?
If the cab mounts are that flattened out to cause an issue then a simple replacement of the cab mounts would gain enough clearance and if I was going to go thru all that work to do the job then I'd swap them out with some poly mounts . Just my two cents .What shape are the cab cushions in? If all else fails maybe a slight body lift? A set of pucks maybe all it takes.
