or How I Learned to Stop Worrying and Love the Bomb!
Cause this HOT ROD DODGE is going to be The Bomb!
Hey guys.
I have a friend who is swapping a 78 440 into a 85 Heavy Half short ton Slant Six Dodge OD manual trans truck. We are looking forward to banging some OD trans gears in a Big Block Hot Rod Dodge Truck! Once the 440 is in and everything is sorted he'll adjust as necessary on the rear end and springs and may switch to a non OD 833 trans. Main thing is to get it running and reliable.
We could use some advice, assistance, counsel, and general encouragement.
Details:
The truck came with a slant six and OD manual trans.
He has a low mileage 78 440 with truck oil pan, motor mounts, and exhaust manifolds that came out of a truck motor home and plans to use the original OD trans, linkage, trans support, drive shaft, heavy half springs, etc.
He has a repro Brewers Big block bell housing with 4.805 diameter bearing retainer opening. Brewers said he could machine the bearing retainer housing down to the 4.805 size.
He has a 26" rad with the outlets on the correct sides
Questions:
What do we need to source to make this swap work and what needs to be modified or swapped to other parts?
Trans cross-member? Plans to use original slant six version - any mods required?
Will this swap change the shifter hole in the floor pan?
What flywheel is needed for the externally balanced 440 manual trans combo?
any issue with the brake booster clearance for the 440?
any issues with drive shaft? we assume not with the same trans as long as it's location is not moved fore or aft behind the 440 vs the slant six and bell housing swap.
What's needed to modify / marry the following:
clutch fork- what are the issues and best method to do this?
Z bar - cut and re-clock and shorten/etc
Z bar and clutch fork alignment / mounting to the frame and repo Brewers BB bellhousing?
Steering clearance - any issues?
Steering sector - any issues?
We'll figure out the alternator brackets etc.
What are we missing and I'm sure it's a lot?
And most of all is there an existing thread where some one has done or is doing this?
Appreciate any help and or encouragement
Hey guys.
Details:
Questions:
