Clint Bazemore
Me again. Just picked up a 1986 D150 short bed. Thinking about selling my 4X4. Getting older and the Two wheel drive is closer to the ground. Having a voltage problem from under the hood to under the dash. Truck has starting issues. I have checked the wiring from the battery to the bulkhead connector. Getting battery voltage. Go under the dash at the bulkhead connector and get battery voltage. Turn the key on not running and the voltage drops to 4 volts and lower. turn the key off and the voltage goes back up. Unplugged the bulkhead connector under the hood and everything looks very clean. Looked under the dash on my 88 W150 and no change between key on or off. What can go wrong between the firewall sides? Not all fuse circuits are getting power either. Have been looking on Aldata with no good wiring diagrams to show all the wires from one end to the other. I built an ignition in a box and the engine runs great. Thanks again for any help in this area.
