Wheel hub
SeanD100
new york
Hello I have a 1965 dodge d 100 today on the way home the wheeel studs in the front passenger wheel came loose and the tire started to wobble . I made it home however I’m afraid the wheel hub may be damaged . The studs basically have to be cut off there that loose . Does anyone have any idea where I could find a replacement wheel studs. Thank you 😊
I’ve looked thru a few parts stores and none had it . I’m not looking for the drum those are easy to find I need the wheel hub the studs somehow came loose and literally stretched the holes so now I can’t put new studs in .
Take what you have with. The wheel stud for length reference and the hub to get a measurement for the new knurl size. Done that dozens of times working the counter at NAPA.
