Tranny swap
jobberone
Ginsu Minion Wolverine
Uuuuuhh....
I have a 350 in my 76 Chevy K10 which works fine. I have a built 200R from a 87 GN. Can I swap this. I know the tail housing does not remove like the 350 but they are roughly the same length with the same output shaft. And I know the mounts need to be built or bought from a conversion shop.
I don't see it working but wanted input.
Thx.
I know this thread is old, no the trans wont work with your transfer case. You would have to get a older divorced transfer case to make it work. I don't know if anyone makes a kit to swap a 700 in if you want OD. You could always use parts from a 80's truck that had OD but you loose your 203 or 205 transfer case.
