The introduction of peedee
peedee
From Australia on the New South Wales central coast area about 1 hour from Sydney i own a 1970 VG regal 770 hard top which is basically the same as a 1969 dodge dart except for the front from the windscreen forward had the same front as the local cars here, i am retired i was a cardiac nurse specialist for many years prior to that i had a business that sold and repaired out door gardening equipment, and prior to that drove tow trucks for a few years mainly heavy salvage using a international transtar or occasionally a ford louisiville
No problems guys will try to help out i do not have a truck i tried a few years ago and back in the late 80's early 90's i drove an aussie truck that was set up as you guys call them wreckers though a lot of the work was not wrecks so much as breakdown work and also used to use a bogie drive international transtar with a cat diesel and roadranger box with rockwell diffs for the big jobbies as where i was based we had a infamous main road that usually once a week had a semi fall over the edge and down anything from 15 to 300 feet, they were the fun jobs for the smaller heavy stuff we also had a ford louisiville single drive
This pic if it works is similar to my small truck the one i took home each night 2.2 ton truck full loaded with just the wrecker back on it, 340 power with 5 speed box and 2 speed diff running on lpg
