    Dismiss Notice
The Dent Side
Discussion in '1973-1979 'DentSide' Ford trucks' started by ramenth, Jun 4, 2011.
  1. ramenth
    ramenthActive Member
    27
    3
    May 28, 2011
    From Wiki:
    Sixth generation (1973–1979)
    Sixth generation 250px-73-75_Ford_F-350.jpg Production 1973–1979 Assembly Dearborn, Michigan, USA
    Edison, New Jersey, USA
    Kansas City, Missouri, USA
    Louisville, Kentucky, USA
    Norfolk, Virginia, USA
    San Jose, California, USA
    St. Paul, Minnesota, USA
    Wayne, Michigan, USA
    Cuautitlan, Mexico
    General Pacheco, Argentina
    Oakville, Ontario, Canada Body style 2-door pickup
    4-door pickup Engine 240 CID (3.9 L) I6
    300 CID (4.9 L) I6
    360 CID (5.9 L) FE V8
    390 CID (6.4 L)
    FE
    302 CID (5.0 L)
    Windsor V8
    460 CID (7.5 L)
    385 V8
    351 CID (5.8 L)
    335 V8
    400 CID (6.6 L)
    335 V8 The truck was redesigned in 1973; the grille for the 1973 model year featured two silver-metallic plastic inserts divided by an aluminum bar that was part of the main grille frame, with the letters "F O R D" spaced out in a thin rail in the upper part of the grille. Large round headlights were on either side of the grille with the park/turn signal lamps placed above in the same rail where the "FORD" lettering was. Medium-duty models, however, weren't redesigned as drastically as the light-duty trucks. In fact they were incredibly similar to the fifth-generation medium-duty F-Series trucks. In 1976, this familiar "split-grille" design was facelifted slightly to feature black accents around the headlights and a refined appearance overall. In 1978, the round headlight design was retained for the regular Ranger and Custom trim levels. The XLT and "Lariat" trim level incorporated rectangular headlights with optional chrome headlight doors and chrome grille insert. The split grille design was overhauled in favor of a single-piece grille insert design. The headlights were also placed in a more stylized "insert" themselves, and the park/turn signal lamps were now placed below the headlights. Additionally, a new chrome-plated "F O R D" letter set could now be seen on the hood immediately above the grille. A luxury Lariat trim was also introduced for 1978. In 1979, the round headlights were replaced by rectangular headlamps across all the trim levels and the surrounding grille insert that framed the headlamps was now available in either black, or chrome to match that of the aluminum grille frame.
    250px-1968-72_vs_1973-79_Ford_F-Series_Medium-Duty.jpg [​IMG]
    The similarities between 1967 and 1972 medium-duty F-Series, compared to those made between 1973 and 1979.
    In 1973, a new model was offered, the F350 SRW (single rear wheel) pickup. These were a new heavy-duty pickup with contractors and camping enthusiasts in mind. The trucks rode on a longer-wheelbase chassis but were the same overall length as an F250 pickup. If you ordered the Camper Special package on an F350 SRW it became a Super Camper Special which was designed for the much heavier slide-in campers coming on the market at that time. Other changes included the 1974 introduction of the extended super cab version. The F-150 was introduced in 1975 to help circumvent coming emissions requirements. These came with a maximum payload of 2,275 lb (1,032 kg) when properly equipped. With the 1/2 ton F-100 still in production, the new F-150 was referred to as the "heavy half" ton by some people.
    In 1976, the F-series became the best-selling truck in America, a position it has continued to hold since. This generation is noted for the durability of the body panels as Ford used extensive amounts of galvanized sheet metal to fight corrosion. 1977 was the first year for smaller cowl insignias moved near the windshield and the last year for the medium-duty F-500.
    The GVWR ratings for these trucks was tied to a combination of wheel, spring, axle and brake combinations. The series code on the ID tag denotes which model and from that it can be determined what weight rating each vehicle has. 4×4 trucks can also be identified by the VIN number and on the ID plate as a serial number. For example, F10 is an F-100 2-wheel drive, but F11 is an F-100 4×4, and so on. Serial numbers beginning with an "X" are SuperCab models.
    Starting in 1978, Ford redesigned their Ford Bronco and based it upon the F-150. The Bronco was now virtually identical to the F-150, except for the unibody design structure. The new Bronco incorporated design characteristics which eliminated leaky roofs and body flex associated with other full size removable top utility vehicles of the era. This allowed Ford to compete better with the Chevrolet Blazer by offering a larger and more luxurious SUV while minimalizing production costs since many (especially the most complex and expensive) parts were shared with the F-series trucks. The Bronco was only offered with the 351M and 400 V8 engines
    Models:
    • F100 F101 F102 F103 F104 F105 F106 F107 F108 F109 F10N: 1/2 ton (4,550–5,700 GVWR max)
    • F110 F111 F112 F113 : 1/2 ton (4×4)(5,250–6,500 GVWR max)
    • F150 F151 : "heavy" 1/2 ton (6,050–6,200 GVWR max)
    • F140 F141 F142 F143: "heavy" 1/2 ton (4x4)(6,050–6,500 GVWR max)
    • F250 F251 F252 F253 F254 F255 F256 F257 F258 F259: 3/4 ton (6,200–8,100 GVWR max)
    • F260 F261 F262 F263 F264 F265 F266: 3/4 ton (4×4) (6,500–8,400 GVWR max)
    • F350 F350 F351 F352 F353 F354 F355 F356 F357 F358 F359 F35P: 1 ton (6,000–10,000 GVWR max)
    • F-360: 1 ton (4×4) (8,550 GVWR max)
    Engines:
    Engine Years Power (SAE net) 240 CID Straight-6 1973–77
    300 CID I6 1973–79
    302 CID Windsor V8 1969–72 130 hp (97 kW) 360 CID FE V8 1973–76 145 hp (108 kW) 390 CID FE V8 1973–77 195 hp (145 kW) 460 CID 385 V8 1973–79 200–220 hp (150–162 kW) 351 CID 351M V8 1977–79 163 hp (122 kW) 400 CID 400M V8 1977–79 169 hp (126 kW)
  2. 70shortbox
    70shortboxMember
    16
    May 22, 2011
    Santa Rosa, Ca
    In my opinion the highlight of the dentside is the 78/79 Bronco. 78 Broncos have an unusual advantage in California (and possibly other states) with their 6000 pound GVWR which sends the smog nazi's running for the books.
  3. 70DartMike
    70DartMikeWell-Known Member
    119
    7
    May 23, 2011
    Could you explain why my 75 4x4 Hiboy has 4 wheel drums, if 73 and up were standard to have discs?
  4. 70shortbox
    70shortboxMember
    16
    May 22, 2011
    Santa Rosa, Ca
    Dana 44? Open or closed knuckles?
  5. 70DartMike
    119
    7
    May 23, 2011
    Yes to Dana 44. Closed knuckles I believe.
  6. RangerRick
    RangerRickNew Member
    4
    Jun 15, 2011
    payson arizona
    I have a 73 Ford F-250 Highboy, no disc brakes, and no power steering, no air.......Im used to it, not bad, keep it well lubed.
  7. 70shortbox
    70shortboxMember
    16
    May 22, 2011
    Santa Rosa, Ca
  8. Exyicon
    ExyiconNew Member
    4
    Dec 8, 2011
    Eastern Shore, MD
    Farm Truck is what I see when I see a dent side. haha.
  9. 65Val
    65ValHardly Ever Here
    7
    Nov 12, 2011
    Canada
    Must be a Chevy guy!!!...haha
    This ain't no "farm truck", bub!!!
    ...and I really wish we could create another name for these Fleetside trucks...I HATE "DENTSIDE"
  10. gray07
    gray07Well-Known Member
    153
    Mar 30, 2012
    michigan city, indiana
    Does dent side mean where the chrome goes down the side.
  11. Coldrodder
    ColdrodderMember
    Dec 13, 2012
    Manitoba, Canada
    Yes. If you look at a truck that doesn't have the chrome, you will see an in"dent"ation running from front to rear along the side.:smile:
  12. mopardad
    mopardadMember
    16
    4
    Oct 2, 2013
    somewhere in Southern Colorado
    Yes, and 67-72 trucks are sometimes called 'bumpsides'.
  13. js29
    js29Member
    5
    Aug 7, 2015
    One of my favorite styles is the 73-79 f series. had A 73 f-250 hi boy tow truck, I put A 79 grill in it. A nice blue paint job on it, some strips, and A lund visor. if not for these rough New York I would still have that truck.
