Mopar to ya
I just bought an 83 Ramcharger. The passenger window never worked and the left did, but has since acted as if the gear or regulator was not working properly. It might move with help for a little bit, then the motor just spins. The right side makes no noise at all. I am taking the panels off later today to check power and ground and all the rest. The question I have is ... the window motor and gear are sold separately. Is it common for the gears to go bad? I only ask before I disassemble because if it's common I want to order them and have them on hand if needed. Anyone know anything about these window issues?
