    Dismiss Notice
Power Loss in 1985 D150 318 2BBL
Discussion in 'General Dodge Truck Discussions' started by Power Wagon 440X4, Apr 12, 2019.
  1. Power Wagon 440X4
    Power Wagon 440X4Active Member
    69
    17
    Aug 8, 2015
    Texas
    Hey Guys,
    I am stumped at what might be causing a loss in power while accelerating.
    At first I thought that there may be a clog or the factory 1985 rubber hoses collapsing in the fuel system.
    Replaced the carb, fuel pump, fuel filter and rear passenger fuel hoses and the hoses on top of the tank.
    Still bogs down when trying to accelerate past 25MPH.
    Then I tried a different ECM to see if it had a bad resistor or something might not be keeping up with the increased power demand.
    Not it either.
    Could a coil or distributor cut down power? It starts right up and idles fine and will rev in park with no power loss.
    Its when you go down the road it bogs down when trying to accelerate. it won't even make it up a hill and dies like its starving for fuel or spark.
    It might be in the tank with a broken or clogged strainer. I did blow back through the fuel line when installing the new fuel filter.
    I'm dreading doing the fuel tank, so I am getting all other options off the table.
  2. 7mopar
    7moparWell-Known Member
    1,509
    585
    Dec 21, 2013
    I would check the coil before messing with the fuel tank. Secondary coil brake down will act that way. You may also want to check the distributor reluctor air gap and shaft bushings. But this really sounds like a coil issue.
    • Like Like x 1
    • Power Wagon 440X4
      69
      17
      Aug 8, 2015
      Texas
      Thanks 7mopar, What about the ballast resistor, could that cut power down if weak?.
    • Polara_500
      Polara_500Well-Known Member
      606
      350
      Aug 9, 2015
      NW Minnesota
      Nope. It either works or it doesn't.
      • Like Like x 1
      • Power Wagon 440X4
        69
        17
        Aug 8, 2015
        Texas
        Yeah I kinda thought that. Just making sure. Thanks Polara!
      • Ralph
        RalphMember
        10
        8
        Oct 9, 2018
        Paris,ME
        I had an 83 Ramcharger with the 318 that got really bad. To the point I kept it off the road. It turned out my intake manifold had gotten clogged up tight with Carbon. Build up. I found it easily after I was told what to look for. I pulled the choke off and it was packed to the top.
        I don't know if that helps, but might be worth a try
        • Like Like x 1
        • Power Wagon 440X4
          69
          17
          Aug 8, 2015
          Texas
          That's something to consider Ralph.
          Thanks.
        • 7mopar
          1,509
          585
          Dec 21, 2013
          Does not the chock well set in the exhaust cross over in the intake? Only thing carbon buildup would do is maybe prevent the choke from pulling off on time.
          • Like Like x 1
          • 65 sporty
            65 sportyWell-Known Member
            1,303
            624
            Aug 8, 2015
            Marlette, Mi
            Just a thought, how much exhaust is coming out the tail pipe? Does it still have the catalytic converter? If you think it could be a problem with the sender in the tank, take a fuel can and run a hose from the pump to the can. If it runs good the problem is in the tank. If you do this though, use extreme caution with the can and how it's secured.
            • Like Like x 1
            • Agree Agree x 1
            • Ralph
              RalphMember
              10
              8
              Oct 9, 2018
              Paris,ME
              On mine the choke well was plugged solid. Also the rest of the passageways were on average far less than 50% open. It took a long time (2 to 3 hrs) to clean the damn thing out. It was as if a nee motor were in there afterwards.
              • Like Like x 1
              • Power Wagon 440X4
                69
                17
                Aug 8, 2015
                Texas
                Choke is working properly. I even put a clothes pin on the butterfly to see if maybe it was closing with acceleration from a weak choke thermostat. same result. It closes when cold and fully opens when warm.
              • Power Wagon 440X4
                69
                17
                Aug 8, 2015
                Texas
                It has dual exhaust with no converters.
                The gas can is a great idea directly to the pump.
                That's what I do when testing an engine that has sat for a long time so I don't pump old gas from the tank.
                I am taking a new dist and coil out there tomorrow and trying it first. Rained hard here all day today.
                • Like Like x 1
                • HALIFAXHOPS
                  1,665
                  940
                  Aug 6, 2015
                  Halifax, Centrural PA
                  Check for slack in the timing chain, sounds like what happened to me on my 87
                  • Like Like x 2
                  • 65 sporty
                    1,303
                    624
                    Aug 8, 2015
                    Marlette, Mi
                    Hops mentioned the timing chain, I did a Ramcharger a few years back, came in as a no start. Fuel pump was bad, replaced the fuel pump and gave it back to the customer. He comes back and says it has no power.
                    So long story short, after spending a lot of time diagnosing a possible fuel issue I checked the timing because it seemed lazy like low timing. Sure enough it was retarded, advance the timing, power is back. I recommend he have the timing chain and gears replaced. He comes in from time to time, but he has since sold the Ramcharger.
                    • Like Like x 1
                    • Power Wagon 440X4
                      69
                      17
                      Aug 8, 2015
                      Texas
                      Chain has been replaced. I will check slack when I am there at the distributor.
                      I always change the timing chain when I instal an engine because of the factory plastic coating thats usually chipping off and chain stretch. Its been a few years since I installed the engine though.
                    • Power Wagon 440X4
                      69
                      17
                      Aug 8, 2015
                      Texas
                      Well guys it was my original thought of it being fuel related. I first put on another coil and had the same result. Then I put on a rebuilt distributor. Same result. Hooked up a gas can with a hose straight to the pump and it climbed the hill like it use to with no power loss. The distributor needed attention anyway because the inside of the cap was black.Cleaned the cap and rotor and set the timing and it ran great. Now I get to tackle the tank.
                      Thanks to all of you for your excellent advice. It could have been any one of those issues.
                    • 7mopar
                      1,509
                      585
                      Dec 21, 2013
                      Fuel filter is external. I would change it before dropping the tank. Poly tanks do not rust anyway.
                    • Power Wagon 440X4
                      69
                      17
                      Aug 8, 2015
                      Texas
                      Fuel filter got changed with the new pump. The poly tank doesn't rust but the sending unit and tube does. not to mention years of sediment from 1985. Been in these tanks many times and they always have crap in the bottom of them.
                      The strainer is probably rotted and not stopping anything.
                    • 7mopar
                      1,509
                      585
                      Dec 21, 2013
                      Must be where you are getting gas. These tanks are not directly vented moisture has to be getting in there some how.
                      Dismiss Notice
