Earlymopar
New in the box Tekonsha P3 trailer brake controller, Model 90195, 1 to 4 Axles - Proportional
Features:
Brake controller activates trailer brakes in proportion to your vehicle's braking action
Automatically adjusts trailer's braking based on deceleration of tow vehicle
Activates immediately - no pausing like with time-delayed brake controllers
Automatic-leveling ability - internal sensor detects deceleration even if controller is not mounted flat
Position at any angle up or down in the vertical plane
5 Storable settings let you customize controller for multiple trailers, varying loads or different drivers
Store display settings, brake type, language preferences, and desired boost level and power levels
3 Boost levels let you adjust initial braking power and aggressiveness
Continuous diagnostic check alerts you to any potential problems
Integrated safeguards protect your vehicle , trailer and the controller
Minimizes drain on car battery by drawing only 3.6 milliamps when not in use
Prevents trailer brakes from overheating by reducing power output to them during prolonged stops
Defends brake controller and trailer breakaway systems against shorts
Customizable, easy-to-read LCD display lets you choose color, adjust contrast and pick from different languages
Built-in, rotary-style manual override lever
Quick-disconnect feature lets you easily remove and store the control when not in use
Replacement wiring harness (sold separately) and replacement bracket (TK5906- sold separately) required to move the controller from one vehicle to another
Plug-in, vehicle -specific brake-control adapter (sold separately) can be used for certain applications to reduce installation time
]Specs:
Application: trailers with up to 4 axles (8 brake assemblies)
Designed for use with electric or electric-over-hydraulic trailer brakes
Overall dimensions: 3-5/8" wide x 4-5/8" long x 1-3/8" tall
LCD display dimensions: 1-3/16" wide x 9/16" tall
Mounting: 360-degree vertical plane operating range
Limited lifetime warranty
These are $185 to $230 depending on the source. Mine, $125 Please PM me here.
- EM
Features:
]Specs:
- EM
