Lost Cab Interior Lights 94 Dakota
64conv65hard
germantown md
My wifes 94 Dakota lost all interior lights in cab and radio not working (dash lights ok). Fuses all good, Bulbs good. Spliced a new wire from fuse box to radio to get that working for her but cannot find where It could have lost feed for all?
You say fuses are good. Have you checked both fuse locations passenger compartment and engine compartment location F1? Did it loose power to the radio itself or to the memory display as these are powered form different sources? Also check the time delay relay for dome and passenger foot lamp at interior fuse box. If the radio works by just running a new hot wire that should eliminate a bad ground but would not hurt to check for bad connection to ground behind dash pad just to right of glove box. Doubt if it solves the problem but check and make sure door switches are still operating properly if one has a broken spring it may think the doors are not opening to turn the lights on. Note door switches wires are ground wires. Hope this is of some help.
All fuses are good (both locations) interior lights and bed light do not work by doors or headlight switch. Radio was completely dead until I ran jumper wire from fuse box to radio.
