"95 Ranger , 4cyl. , 5 spd , turns over , eng. lopes , but won't start . May start fine for several days , then Bam ! New starter , new plugs , wires , fuel filter .
Welcome. I guy I know that works at a Ford dealership told me one time that there was 2 different starters for some of the rangers. I can't remember what yrs he said tho. You may want to go by and see if that is what could be causing your problem
Welcome aboard from NJ. As mentioned above, check your trouble codes and listen for the fuel pump when turning key on. My son's 93 jeep went through similar last week. Cam position sensor (inside distributor) had gone out,(no signal). The code did tell us what it was after the key dance however, it did NOT set the engine trouble light! Good luck!
