How wide can you go
tls85
Alberta Canada
So I recently came into my dad's old sweptline. But of a Johnny Cash unit as he called it. Registration says 68 front clip headlights tell me it's a 62. Anyways. Doing a disk brake conversion because everything's seized from sitting and the price is right. Wonder how wide of a tire she can fit at stock height? I like the road course racer stance and hoping I can fit 11wide up front and 12+ in the rear. Has anyone ever tried this or know?
Thank you
So. If anyone's curious on a 2wd I've got 10" wide wheels with a 3.75 backspace and run 295 up front with no issue
You know you still have to turn them things to go the direction you want to go.
They will also ware components faster. But I that's what you want.
3.75 backspace allows me turn full turn. No rubbing no issues. And yes I know oversized tires are harder on joints and bearings
At stock height, the wheel wells on these trucks are narrow.
An 11-inch wide tire up front will likely rub when turning.
In the rear, 12-inch or wider may fit only if the backspacing is right and the axle is centered.
You will need to measure from the frame to the fender lip to see the space.
It may require different wheels or a small lift to avoid rubbing.
