Polara_500
Looking at spiffing up an old distributor to swap out the old one in my 87 W250, converting it to a single pickup unit for simplicity and got a question or two - and since you're now our resident distributor 'spurt you're on the spot.. The FSM talks about lubing the governor springs before reassembly then using distributor cam grease on the support buttons under the plate - so........
1 - what to lube the governor springs with?
2 - what is/where do you get distributor cam grease?
Thanks for any help.
Mike
Mike
