Cost= a lot you would be money ahead to get a complete parts truck to swap everything over. Preferably one that was wrecked just enough to total it. That way you know exactly why it's only for parts.
Items on the "needed" list to my knowledge:
Pedal assembly
Trans is a given
Possibly computer and wire harness.
Flywheel/flexplate
New clutch would be the best way to go as I would never re-use someone else's old clutch assy
I'm not sure if the driveline is different.
Shifter assy is another given, but i know they make aftermarket short throws for the trucks too if you want to get a little crazy
Like I said, beat way to do it would be to get a parts truck so you can pull everything at once and get it laid out for the swap. A good parts truck should be able to be purchased for $100-$300
