Engine swap
Casca2525
Ontario Canada
Have done a few basic swaps, couple Hyundai ponies, sbc to sbc, sbf to sbf sbf to fe, no mopar, now that it's thawed out enough to open the bay door, I Can pull the 360, the 440 donor was prepulled by the owner, so any heads up, hints tips etc for my first sbm to bbm swap would be gratefully accepted
79 tradesman, currently has a late 60's early 70's 360, due to the 1979, 360 externally combusted
Putting in a 75 440 out of a new Yorker
Big Block motor mounts for pickups and vans are not exactly easy to find, but there out there. The hard part will probably be the oil pan and pickup tube, Mancinni has them (they ain't cheep). Exhaust manifolds for trucks are center dump and are prone to cracking in the middle. Big Block A/C radiators are getting almost non-existent in good condition, however... Slant 6 A/C or heavy duty cooling is the same, both have the inlet on the passenger side. The version is a little more common and some parts houses still list that application. The engine wiring harness will need to be a Big Block version or you'll need to modify the wires going to the distributor and coil.
No need for the short tail shaft trans. I've only seen them in the RV's with an extended wheel base or ones with GVW at 10,000 or greater. The short tail shaft will require a two piece drive shaft also. Just match to what you have under there to keep things simple.
Ok,,, I have hedman headers, the 360 trans appears to be the same leanth as the 440 trans, I seem to remember it being a 2 pce drive shaft, currently missing psp, and alt, any chance of using the alt, psp and belts/pulleys off a 3.9? Lastly need a cooling fan, the 440 and 360 were fanless, when I got them, I have a 318 fan but it's only 5 blade, and smaller diameter, I also have a mildon 7qt oil pan for trucks/vans, and iirc 1/2" rear sump pickup
Some progress stripping off the house, after it opens we will make a dump run and a scrap run, just have to separate the aluminum sheeting from the rotton wood
Unfortunately there will be nothing usable from a 3.9. Brackets are all wrong, pulleys are likely serpentine. If you just have to have serpentine its best to buy a kit. I would stick with V belts. Available almost any where.
But if you have a machine shop with all the goodies and can fabricate metal anything is possible.
Power steering pump pully has me held me up, all the rebuilds i have found need me to have a good pully and a reservoir, that's why I grabbed the 3.9, twin v belts, 93 amp alt, and a good ps pump, sadly no longer have access to a lathe or milling machine
87-90 3.9s were still v belt drive. Some things may interchange off of the front of it. Id rather take the alt and ps off of the original engine though
Didn't get them, they went with the donor car, I Can, Im told use the pump from the 360 that came with the rv, that just means I only have to find an alt that I can afford, as the alts from both rvs are seized solid, it sucks the auto electric guy in town is 6-8 month backlogged otherwise I'd just go see him
