    Dismiss Notice
Engine problems
Discussion in 'Dodge Dakota' started by Drache, Sep 14, 2015.
  1. Drache
    DracheMember
    13
    Aug 14, 2015
    British Columbia
    Ok I'm having a problem with a random miss in the number 6 cylinder on my 3.9L
    I've changed the injector (even swapped injectors on other cylinders), changed the spark plug (even swapped spark plugs on other cylinders), tested the spark plug wires, and changed the distributor cap.
    Now the weird thing is, the one mechanic I took it to couldn't figure out the problem. He said the random misfire only happens at idle. Not when actually driving the truck.
    What else could be causing the problem?
  2. 65 sporty
    65 sportyWell-Known Member
    575
    169
    Aug 8, 2015
    Marlette, Mi
    Ck for a vacuum leak
    • Like Like x 1
    • Drache
      DracheMember
      13
      Aug 14, 2015
      British Columbia
      None could be found
    • kiwigtx
      154
      57
      Jun 16, 2011
      Auckland
      Sounds like you've changed out the obvious stuff....I'm wondering if there is an issue with the valve train, or a carbon-ed-up valve.
      I had a serious miss on No.1 in my GTX years ago...it was a spark plug. Damn thing wouldn't let me go over about 40mph in top gear.
    • 65 sporty
      575
      169
      Aug 8, 2015
      Marlette, Mi
      I have never seen it on a 3.9 but you could have a broken valve spring
    • Drache
      DracheMember
      13
      Aug 14, 2015
      British Columbia
      Forgot to mention, compression is 100% the same in all six cylinders.
    • kiwigtx
      154
      57
      Jun 16, 2011
      Auckland
      mmm....that's not leaving a lot of things to look at.
    • 7mopar
      7moparWell-Known Member
      841
      102
      Dec 21, 2013
      Random misfire can be caused by about anything that moves and can knock. Have solved it by replacing tierod ends. Time to start looking at the not so obvious.
    • Cranky1
      Cranky1Well-Known Member
      143
      25
      Jun 4, 2011
      Does the computer throw out any code? That's about the only other thing I can think of. Even if it doesn't produce any codes, it could be causing it. How about looking at all the connectors to it? I recently had to do some work on the bulkhead connector on my 95 due to corrosion. I also made a water deflector to keep the water from hitting it whenever the hood was opened plus the rubber deflector wasn't doing a good job either.
    • 440roadrunner
      440roadrunnerMember
      4
      Aug 9, 2012
      N Idaho
      How about the wiring to and or injector connector? I've seen these "noids" you can buy to hook to them for testing. Don't know about those ones..........
      Wiggle the connector while running, unhook it and see what difference........
      Do these have the bottom intake cover like the V8s?
      What does the plug look like? I still "lean" (pun intended) towards vacuum leak. Remember, they can leak from the valley, as well.
    • owlafaye
      owlafayeMember
      13
      5
      Nov 10, 2015
      north west coast
      Separate your plug wires with some old innertube.......you would be amazed how wires leak strange currents.
    • moe7404
      moe7404Member
      5
      Feb 17, 2013
      wichita kansas
      check the throttle plates for carbon buildup. i have been having trouble withe my engine dieing at idle. in my search for a fix i found out that the plates should be closed at idle. and if you mod the throttle body to crack open the plates the computer will try to adjust for that. also some guys do a mod to the TPS by drilling the holes a little and rotating the TPS housing. there are some good posts on some other sites about dieing at idle that have a lot more info. also when starting the engine dont open the throttle plates. because the computer uses that as a " 0 " set point for running the engine.
    • 7mopar
      841
      102
      Dec 21, 2013
      Hope this was fixed long ago. Original post was Sept 2015.
