stroller
Ok so I know many have asked this to which I am sure. But with I have not seen a question in the way I am seeking advice.
Ok so I have a '79 Dodge D-150, 360, A/T. Ok I have removed to EGR and assorted emmisions devices. With that the electric choke had a wire from the egr control supplying voltage. The choke is the one mounted on the intake not on the carb.
The harness for the egr plugs into a "control box" mounted on the drivers side fender right behind the diagnostic port, which I have never found anything to hook up into. The power for the control box comes from a red wire with a bullet connector and all the red wires from that harness are tied back into the single red wire that plugs into the control box, of the 3 wires that share the plug.
Has anyone ever just simply ran a wire from that main red plug over to the electric choke with success? I am trying to figure where to pull power. This is to the little 2 spade connector that mounts on the intake which some versions were a ceramic rectangle block with 2 spades and then others with what I have is the little disk that is mounted on the mounting strip with the 2 spades, 1 for the choke the other for power supply.
Any help would be appreciated.
