Do you have access to live data? What is the timing reading? If the timing is in range will elinimate the timing chain. Check or replace camshaft position (CMP) Sensor. Check electrical connections and wiring harness for damage. Chryslers description: The engine control module (ECM) detected the actual CMP position disagreed with the expected level.
