restore 3
Gunshot 22
Thanks again for the info. The fluid, bolts and the data on the axle housing and vacuum line and sending unit all make sense and while I dont have that CAD axle, I can tell you that putting the wire on the sending unit BEFORE installing the T/C would have been a good idea! lol I'm prepping for the NE storm so today was pretty hectic! The Bolts on the D/S flange will not take 7/16 or 10mm. I researched an article that used lock nuts and longer bolts, and another where they drilled the holes out to 7/16 and then tapped them? Needless to say the 3/8th bolts torqued in then locked up was the logical (Spock) way to go. Tomorrow will be the test!! I'll pick up a set of mile markers tomorrow also. put them in first thing. This is a no licensed off-road snow plow so I have a little lea way. Ya know I was all over that axle and the only #s I found were casting no.'s and the ratio tag. (4:56's) thats it. No BOM tag and no numbers on the axle tube? I have no clue what this is Im guessing a Dana 60 from the early 80's. Im just gonnna have to match the hub at the parts store I guess? All else is cool. Thanks again.
