Go to "Cyclops Adventure Sports", That have a replacement LED bulb to but in the existing headlamp. housing.Just take your 9007's out these in! PLUG & PLAY Be careful on install as you need to follow directions in order to get the cut off line of the beam set correctly. It is actuall simple BUT NEEDS TO BE DONE. Or you could blind the world. Part no. CIL-LED-9007 that's 7000 lumens (50 watts)on high beam. I believe 3000 on low (30 Watts) only $65 each. Got to be an "old Fart" to know these things.
Go to Summit Racing or Jeg' High Performance for wheels - I like the Summit site and service better but use both. Just got a cat back 409 Stainless< sigle tail pipe exhaust (MBRP) and K&N cold air Systen for my Ram.under $1000 for both systems to my door.
