904 transmission question
work truck
Florida
I have an 87 Dodge d100 two wheel drive with a 360 and a 904 transmission that has recently been rebuilt. I was doing a little pull this morning and as I got back in my truck this afternoon it was shifting very sluggish as if there was no pressure on the kick down the cable does anybody have any Incite on something that could have let go internally. Thank you in advance
Fluid level up to where it should be checking in neutral and at operating temp? Who did the rebuild? Is it a shop and have a warranty?
That's why trucks came with 727's. Unless the 904 has been beefed up a bit, they are a bit light duty for towing or heavy duty use. Does it hold once in gear? Just sloppy shifts? I'd for sure put in a shift kit and run the line pressure up quite a bit. Naturally the kickdown linkage (or cable if you've converted it) needs to be adjusted correctly or it can ruin a good transmission.
