77-81 2WD 1 ton front end pieces from a Crew Cab
nothingbutdarts
Bailey, Co.
I think I have a 79 1 ton Dodge Crew Cab, 2 wheel drive, have calipers, rotors, spindles and anything else on the front suspension if you need anything. Have hood & fenders as well. It has Quad headlights.
$150.00 or best offer plus shipping from 80421 (Bailey, Colorado)
If the lug studs larger than 9/16" & the door tag has a front axle rating of 3800# & heavier then you have a one ton
The only CrewCabs that were one tons were the 2WD LWB 165" Like mine single wheel or dually
Well, no drivers door on it, that's why I'm not exactly sure of the year. It had a DANA 60 "HD" in the rear. It was a long bed and I believe it was a military truck as well. I think the wheel lugs are 5/8" Big mothers!!!! I put the rear diff. from this truck under one of my other 4X4 Crew Cabs that lost a pinion bearing. Now it has two different wheel lug sizes and rim sizes because the lug holes are so big.
