69 240 pink resistor wire
thinman666
Georgia
1969 240ci p/u. Can the pink resistor wire lose it’s resistance and still deliver full battery voltage or does it just break the circuit when it fails?
I’ve got full voltage at the ignition coil with the ignition switch in the “run” position.
Thanks
Hey @thinman666, the pink resistor wire in your '69 240ci can degrade over time. Typically, if it fails, it might not completely break the circuit but can lose resistance, resulting in full voltage at the coil. This can lead to overheating the coil or burning points. It’s worth checking the wire for any visible damage or considering a replacement if you’re seeing full voltage. Good luck!
