46RE transmission shifting up and down Erratically through gears at highway speeds when passing
RammerJammer
St John's ,NL,Canada
Hey folks, I have 2001 Dodge Ram 1500, SCSWB 2WD that I'm having an issue with.
5.2 Magnum/46RE Transmission
When on the highway and passing other traffic, the transmission keeps shifting erratically up and down through the gears.
I'm thinking it should hold the passing gear and then smoothly select 4th gear but that is not the case.
Also, in town , I have to modulate the upshift with gas pedal pressure or the vehicle will over rev until I back off the throttle, then it shifts.
Any suggestions?
Possible governor pressure solenoid??
Here's a pic of my truck.
Could be the shift solenoid or pressure solenoid. Someone makes a kit that has them in a set, maybe Sonnax? Try running a bottle of ATP AT-205 in the tranny first. The solenoids may just be sticking & the AT-205 may fix your problem. I've used it with great results. It's worth a try. I know Amazon has it. $20 or so for a small (8oz?) bottle though.
Thanks for the info niceolddart!
The truck has 150,000miles on it and is completely original including the paint so maybe its time to replace the solenoids anyway.
Other than that ,its very reliable and still gets 16mpg which I'm told is very good for these trucks.
Some company makes an up-graded solenoid kit for these but I'm not sure of the company name. I'm sure you can find them on the internet though.
On mine it was the band needed adjusting very simple to do and easy access from underneath on drivers side. Look up procedure and try it nothing to lose.
My 2001 Dodge CTD did that years ago. Turns out there was a bad solenoid in the valve body. Took it to a trans shop and they fixed the problem
That trans specked oil as ATF-4 so watch what you dump into to if you don't want seal destruction. Newer fluids and not as acceptable to stuff never intended to be dumped in regardless of what the aftermarket thinks.
