42RH into my 87
Well, after the ATF cleared out all the cylinders were re-tested truly dry.
All at 140-145psi save cylinder 6...best i could get was 125.
Still not bad, probably gonna run it.
sb
So...pulling the trigger on the leak down tester. What percent is reasonable to still run with...that is, go thru the angst and frustration of installation and set up of the Magnum/42RH in my truck?
I guess, where I won't be disappointed in performance and oil consumption...
