1995 Dodge Ram 2500, 2WD, Reg cab,Cummins,12valve Diesel -solid,So. NJ, $5400
crossy
Pennsville, So. NJ
1995 Dodge , 2WD, 2500, 12 valve cummins Diesel.auto,posi.173K miles. I buy older cummins trucks , and SOME gassers, just to save them(hobby). this one was no exception. ONLY mods to engine are 4" exhaust & BIG airfilter(BHAF),
GOOD=All safety issues I could find were fixed, 4 new shocks, 4 new ball joints & pitman arm. Safe & meaty, load 'E' rubber(tires). Safe & meaty brakes. Loaded with Power accessories ,tilt, cruise ,and NOW everything works. new TPS. A/C just sucked down & blows cold. Got 14 MPG towing 6500 lbs up & down turnpike. Les than 200K on engine, so it will probably out live you now.
INTERIOR= Nice radio & speakers, brake controller.dash has normal cracking, but better than most.
BODY= Clean inside and underside of bed. doors are NOT bad(minor rust on bottom of left door, but not through like most). Only top surfaces are sun damaged. straight other then dent mentioned below.
BAD= needs alignment now, missing side molding on right side of bed. sizable dent in lowest part of right front bedside. rip in driver seat(i got estimate of $150 to fix),needs valve cover gaskets(I have them and EASY to replace).
I know NOTHING about the past history of this truck other than it lived in Central New Jersy all it's life (minimal salt use) - The auto trans (47RH) shifts better than it should for age and has probably had something done to it ?. Very Solid for age & area we are in. $5400. is the ONLY price- I will not take a penny less
"--- IF IT'S STILL LISTED, THEN I STILL HAVE IT - No matter how old the ad is. ---------Sorry , but I do not negotiate my listed price. What that means is Don't call or email unless you will pay the price it's listed for. I also don't answer any emails offering le$$ money than it is advertised for no matter how old the ad is either. ----THANKS FOR LOOKING. >>>>>>>>>>>>>>>>>>>>
David- phone#- PLEASE DO NOT TEXT & PLEASE READ THE WHOLE AD BEFORE YOU CALL- 8 5 SIX- 6 9 three- 091eight, 9am-9pm, IF YOU LEAVE A MESSAGE , please speak clearly , I am a 12 hour shift worker so be patient. don't call about parts that I Don't have listed. see what else I have by hitting the SEE USERS OTHER ADS link that craigslist provides. >>>>>>>>>>>>>
LOCATION-Pennsville,N.J. - I'm 5 minutes from the base of Delaware Memorial Bridges.Routes 40,140,130,295 & 95(NJ Tpke.) all converge here in Pennsville so I am easy to find and get to. >>>>>>>>>>>>>>>>>>>>>>>>
I am NOT parting out the truck, I'm also NOT a business. >>>>>>>>>>>>>>>>>>>>>>>>>>>
search words- turbo turbocharged, 4/s 12valve, 12v p-pump p7100 p-pumped 5.9 5.9L CTD 2ndsecond gen generation 2 gen 2ndgen 94-02. 3500 2500 3/4 1 ton 1994 1995 1996 1997 1998 94 95 96 97 98 landscape landscaper RWD 2x4 deisel regular cab rc rclb lwb
