1993 Dodge Cummins
Dodge Diesel
  1. moparp215
    moparp215Member
    6
    Jul 30, 2011
    Florida
    93 354,834 miles an only normal maintinance.
  2. stansgray03
    stansgray03Well-Known Member
    468
    16
    May 23, 2011
    Marysville, WA.
    I'd say it's been around the block a few times.:smile:
  3. moparp215
    moparp215Member
    6
    Jul 30, 2011
    Florida
    And Still avg 28MPG(depending on where I get fuel.Amsoil Fuel concentrate ,Cetane boost at every stop
  4. black gold
    black goldActive Member
    40
    Jun 29, 2011
    Funny thing, I had to look 3 times I thought it said 93,354,834. I know of some people have a cummins up past 400,000. I've heard of 600,000 but I think that is bull.
  5. moparp215
    moparp215Member
    6
    Jul 30, 2011
    Florida
    I'm probably
    I don't think I'll wait too much longer I know the pump is weak.
    I'm looking for a rebuidable core so I can start on my back up.
  6. Dodgetkboy78
    Dodgetkboy78Member
    24
    May 27, 2011
    LOL
    HAHAHAH
    HAHAHAHAHAHEEEEEEEEEEEEeeeeeeeeeee!!!!!!!!
    I would have 800K on mine if the speedo hadn't quit working a month ago..... I really should ix it.
  7. Bob Cain
    Bob CainActive Member
    93
    10
    Jan 19, 2012
    Coquille Oregon
    305,000 mi still strong 1997 3500 4X4
  8. d5679
    d5679Well-Known Member
    160
    4
    May 22, 2011
    Foristell mo
    If you can rebuild a lawnmower you can rebuild that pump.92 pushing 500- 93-460 I don't know about bull but these cows still run hard.I am going to try an 85 speedometer these 100's don't last.Anybody tried this ?
  9. Mopardude
    MopardudeWell-Known Member
    258
    8
    Jun 15, 2011
    Elkhorn, WI
    With that many miles on it have you ever had problems with the so called killer dowel pin that supposedly plagues the first gen cummins?
  10. d5679
    160
    4
    May 22, 2011
    Foristell mo
    If you are talking to me-I don't know anything about a killer dowl pin.The only dowel pin that I think could cause a problem would be the timing pin that you push in to hold the engine while you take off the pump.Is that the one?
  11. Mopardude
    258
    8
    Jun 15, 2011
    Elkhorn, WI
    No its not that pin! The pin I am talking about is on the front side of the engine. The pin you are talking about engages the cam gear I think. The killer dowel pin is at about the 8 or 9 oclock positition to that gear. I have only ever heard anti dodge guys and 1 Cummins guy I know talk about it. I was just curious if it was something to really worry about with the first gen cummins or if it was something that is known to happen but doesn't happen really that often?
  12. Mopardude
    258
    8
    Jun 15, 2011
    Elkhorn, WI
    Was just talking to who ever had an answer! LOL
  13. d5679
    160
    4
    May 22, 2011
    Foristell mo
    Sorry I don't have an answer -never heard of that pin.Have had seven 89-93's biggest problems are trans and rear axle-and heater switch.
  14. moparp215
    moparp215Member
    6
    Jul 30, 2011
    Florida
    Ok now at 359.000 and my trans broke.This is the first major expense.Si Si can't squeek tooo hard.
  15. caferacerx
    caferacerxMember
    13
    Jun 18, 2011
    I only have 200,000+ on my 97 ram 4X4 3500 12 valve, hardly broken in,
    it is on it's second trans (auto, should have gotten the 5 speed I guess)
  16. Bob Cain
    93
    10
    Jan 19, 2012
    Coquille Oregon
    Killer Dowel Pin! What is it?
  17. Mopardude
    258
    8
    Jun 15, 2011
    Elkhorn, WI
    Its an alignment pin for the timing cover or what ever its called on a cummins. Supposedly there are known to work there way out and when that happens its bye bye engine. If you google killer dowel pin or go to youtube and look it up there is hundreds and hundreds of links on this issue but you come to any dodge forum and you never see any posts about it.
  18. Bob Cain
    93
    10
    Jan 19, 2012
    Coquille Oregon
    Thanks i will check it out
