    Dismiss Notice
FOR SALE 1992 Dodge Dakota Rolling Chassis For Sale
Discussion in 'Trucks for Sale' started by Kajun cummins, Mar 12, 2018.
  1. Kajun cummins
    Kajun cumminsNew Member
    Mar 12, 2018
    Bourg, La
    Contact Seller
    Selling as a roller with no engine or transmission. $6,500 negotiable
    Truck is set up for small block and 904 transmission.
    6 point roll cage
    8 ¾ rear end with back brace
    4.56 rear gear with a spool
    Race axles with 3” studs
    Cal-tracs with single leaf rear leaf springs
    Adjustable race shocks
    Areomotive fuel pump with regulator
    Steel braided fuel lines
    15 gallon fuel cell
    6AL MSD
    MSD ignition coil
    Ceramic coated headers
    3” exhaust and 3” Flow master mufflers
    Duel racing seats
    5 point shoulder harness
    Centerline Warrior wheels 15 x 10 rear 15x 3.5 front
    Hoosier front racing tires
    Wildwood front disc brakes with 3” wheel studs
    Hoosier Rear racing slicks 30 x 10.5
    Factory rear drum brakes
    Fiberglass cowl induction hood and the factory steel hood
    Rear roll pan
    Tonneau cover
    VDO tack with shift light
    Manuel Auto meter oil and temperature gauges
    Electric radiator fan
    Turbo action shifter
    Setup for dual batteries with battery cutoff switch
    Factory gauge cluster, factory wiring harnesses, dash and steering panels are available to make truck street-able if so desired.
